MKSeven
- Las Vegas, NV
- mk7 gti, duh.
Update on this?
I don't think that second photo is quite right, there has to be machined recessed surface like in photo 1 and 3 where the thrust washer is located.
Item 9 in the diagram is the infamous thrust washer.
Also axial play of the crank is limited to 0.07 to 0.30 mm.
Except it's not really unlubricated. Oil with a good film strength is providing lubrication.I'm talking about the un lubricated lateral force applied to the crankshaft and thrust bearing when the clutch pedal is depressed on startup
I'd use a dial indicator on a mag mount.Would it be possible to measure thrust bearing wear using a dial bore gauge on the damper/pulley? The idea is that the pressure plate pushes the crankshaft against the thrust bearing towards the passenger side right? In the service manual there is a page on "measuring axial clearance" with a dial bore gauge with a clearance of 0.07-0.23mm and wear limit of 0.30mm. I really wonder if this measurement can be done outside the engine using the clutch to push the crank.
Though I might be over my head here...someone who knows what they are talking about chime in.
what would be the course of action if crank axial play measures near the .3mm wear limit?
