What’s the thought on running engine mounts without trans mounts?
El_bigote_AJ
Las Vegas
2019 GTI bunny
I got it. There isn't a dunce cap emoji so I just said duh.
Ah I see, I thought you were using the duh as “obviously” 😂
You wanted to use it as the:
not_the_feds
1983 and 2016 GTI
It's definitely worth just doing both sides if you're already going to do one. Like a bunch of others said, they compliment each other and are designed to work in conjunction with the whole set.
okMK
AZ
16 2dr MK7
With my work done, I have to strongly encourage you replace the trans mount. Its probably way worse off of the two.
Daks
Toronto
GTI PP
That's the hard one to get to though... :cautious:
Yeah - both at once seems like the play.
