Six Speed Tsi
- Newmarket, ON
- 15Mk7 Vw Golf 1.8Tsi
Soooooo……… I need help. i got the is38 file from reflecttuning and now this happens. (not even 24hs having the tune on the ecu). i had no problems with the jb4. I could be at any throttle position and anytime over 3000 RPM it cuts throttle or fuel i don’t really know or it’s not giving throttle to the engine. it happens in boost and not in boost this still happens. anyone know what it could be. ian said it’s not the file but ONLY happens when i flash the is38 file on it. When I put the is38 on I used the wastgate from my is20. is20 wastgates are different than factory is38 ones but it’s in spec i double checked. I flashed the car back to stock connect the jb4 again ran my map6 which hits 30psi and i didn’t have an issue then flashed reflecttuning’s is38 file (jb4 100% unplugged) and boom same problem. i’m looking on obdeleven the throttle position sensor and i push the pedal down like 17-25% and the turbo is trying to make over 15psi, feels like a reeeeally sensitive throttle. any help would be greatly appreciated. these are the codes i’m getting. no epc light or check engine light on at all.
6 Speed manual transmission swapped from mk7 gti pp (2016)
(Gti) ECS Stage 2 Clutch Kit
3Inch CTS Catless Downpipe W/Stock Gti Catback
Injen Cold Air Intake
Golf R Intercooler
Golf R/S3 Turbo is38
AEM V3 Water/meth kit 500cc (may upgrade to 1000cc)
2.0 GTI/R HPFP (Autotech Internals)
93Aki
Golf R Intercooler
93Aki
