Weathertech Side Window Deflectors
OldVWFan
NW Arkansas
17 GTI Sport
Would appreciate the opinions of those using this exterior modification as to their functionality, that is, do they reduce wind noise when the window is down or partially open, do they prevent rain from coming in when the window is cracked open, and any other comments as to durability, etc. Thanks.
RobertJG25
Niagara Falls, ON
2019 VW Golf 1.4 TSI
I have the oem VW ones, I don't find they make a difference for wind noise with the windows closed. No more, no less, despite saying they should reduce wind noise. For the windows down, I used to find that if I had the drivers window down a bit (a little to halfway), or just the front two fully down there was A LOT of buffeting and uncomfortable pressure in my ears if the rears weren't also down, but now that is pretty much gone with the deflectors. I haven't had the windows down while raining yet unfortunately. The rear VW ones seem to stick out in the middle more than I'd like, its not a huge deal, but I think the Weathertech ones are more flush.
Datboireal
London
Golf Mk7 GTD
I have the henko wind deflectors installed on my Golf. I feel its added a bit more wind noise when travelling at speed when the windows are up but when the windows are opened slightly it gives off less noise 🤷‍♂️. Not an issue for me as it's liveable compared to the rain that used to trickle in when the windows were slightly ajar. Now I don't have this issue with the wind deflectors installed. Only had them on for a few months now so can't give an opinion on the longevity but there still looking clean and nicely secure since I installed them.
swcrow
Virginia
7.5 GTI
I literally just installed the weathertech deflectors. They were a super easy install and after leaving the windows up for 12 hours per the instructions, I have not run into any issue with the auto up function of the window. I love the low profile look
StorableComa
SoCal, USA
17 GSW S FWD
Had them on almost a year on my GSW. There is a bit of noise at speed with the windows up, nothing your radio can't cover as mentioned above. With them cracked the air stream is less harsh and not as noisy. No issues with them cracked and raining on all 4 so long as you don't go lower than the outside deflector lip by much.
Make sure you line them up right on install. Had to fuss with the rears a bit, but once in place and allowed to sit for 12 hours i've had no issues since.
cbenjes
Bel Air, MD
I've had them on both my Mk6 and Mk7 GTI. No reduction in wind noise, but they are great for parking in the sun and cracking the windows to vent the summer heat. I also have them on my wife's Nissan Rogue. Well, I HAD them on the front and back of the Rogue, but the back ones blew off and are gone. No trouble losing the ones on the GTI, but the security on the Rogue's rear windows sucked.
swcrow
Virginia
7.5 GTI
I have the weathertech deflectors and love them....super low profile and incredibly easy to install. If you follow the directions exactly, you'll have no issues with the auto up feature. Any addition will add wind noise, but it's not much....way less than my roof rack when it's on.
hotbascosauce
Seattle, WA
19 GTI SE DSG W/DCC
I have the Weathertech ones that I bought from their Amazon store. They're great. No wind noise. And now I can roll down my windows in the rain when going through a drive through for food or coffee and not have all the rain water fall onto my window switches. Definitely a must for the PNW.
mk6'12gti
Cleveland
2018 Mk7.5 Gti
I also have the weather tech visors. I had oems ones first and got rid of them cause they were loose sitting in the window channel. Swapped to weather techs and have zero complaints they fit alot tighter in the window channel.
neoupa2002
Canada
2019 Golf Wagon
Do your folding mirrors contact the Heko wind deflectors? And did you install with the clips or did you go double sided tape?
Datboireal
London
Golf Mk7 GTD
They do make contact with the mirrors when they fold up, but they only touch a little and they haven't affected the motors since I've installed (coming on three months now). I used the supplied clips to afix them too and they've not given me any trouble either.
neoupa2002
Canada
2019 Golf Wagon
I'm having some major trouble with mine, the front ones are loose and just recently got flung off in the car wash. The clips are still intact as well.
Datboireal
London
Golf Mk7 GTD
I've only taken my through the car wash once with them attached and they were fine. I do avoid car washes though and wash by hand. Try reach getting in contact with the company you brought them off for a exchange/refund
HelloNewman
SoCal
Mk7
I recently installed the WeatherTechs and I have to say the wind noise is pretty loud. A coworker has a pair (on a different vehicle) and he said the double sided tape that they put on visors is insufficient and that is what causes the extra noise. I'm a little bit hesitant to reinstall them again. I did notice on the drivers side window the bottom corner is bowing out a bit, not sure if normal?
