2015 golf gti.
Ive recently noticed that ive a leak which is causing the passenger footwell to be wet. After removal of my seat, pulling the carpet back.as best I can ive tracked the leak to immediate left corner.
After a water test it looks to me that the water is running through the car properly ( coming out just beind the wheel) but this is also causing water to seep into and run into the foot well. What is the route the water takes when it runs through the right hand side of the picture. The picture shows the right wing ( looking rearward) scuttle panel has been removed.
From what I can work out the water travels as shows in the picture below.
Has anyone else had this? And possible fixes?
Also - the foam on inside of the wing seems to be retaining lots of water. Could this be a cause? Im almost out of ideas other than p/x the car.
Any help would be greatly appreciated.
Thanks.
Thanks.
