normcaldwell
- Denver, Colorado
Going to order S3 PCV after seeing your experience. I just got back from a track day and had my first case of oil surge/white smoke. Didn't think it would happen as I am on 280tw Yokohamas but after a few high g turns it through a big cloud of smoke behind me. Got in on GoPro and uploading the vid now. Scary stuff.
I had a '16 GTI prior the current ride. At the time (about 3 year ago), I had the stock PCV plate and the Wortec oil pan (do not get this pan).
Got the black flag after a couple of laps. Pulled into the pit, and the guy asked me to open the hood. I'm a bit OBC about keeping the engine bay clean.
He was stunned to see a clean bay, lol. By then, I'd become aware of the issue, and had tried the VWR system. At the time, the VWR design led to a leaking cap on the plate; annoying. I re-tried the stock PCV combined with the Wortec pan, and holy crap. Smokefest. Re-installed the VWR system, using gasket sealer around the cap. Solved the cap leak, and the smoke issue. However, with the VWR setup, I'd still get a fair amount of fluid in the can.
When I picked up the S3, I happened to also come across the DBV2 thread in MK7 forums. The DBV2 guy, Dan, had an S3 with his DBV2; and he said the 'BL' plate solved the issue for him. Rather than install the VWR kit, I tried the BL plate and the ECS catch can kit.
Dan referred to the PCV as the B9 A4/A5 plate. I'm pretty sure it's not the stock R/S3 plate.
Awesome, that'll be my next purchase. Thanks for the R&D.
Best on the pan! Looking forward to how it works for you.
