October 2022,
The Main Service.
Part 1
For starters the car’s 8yrs old now!! ….How time flies!!....
The timings of every 2, 4, or 5 years means this year was a big service!
First of all, time for me to do my parts of the service:-
Engine oil & oil filter change
Engine flush
New spark plugs
New cabin air filter
Gearbox oil change
Wash & reoil the ITG engine air filter.
Engine Oil:-
I decided to get the same engine oil as I have previously been using, Castrol Edge Titanium FST 0W40, which is VW502 00 approved. I change the oil every year which means I'm on a "Fixed" service so can use a VW "502 00" spec oil instead of a "504 00" flexible service specification oil which is usually a 5w30 grade! OEM oil filter & sump plug washer from the dealers parts dept. were also used. Every two years I also "flush" the engine oil out with "Wynn's" engine flush, & it was this year. So, I went on a nice 80+mile drive before doing the flush/oil change, so the engine was HOT!!!
Spark Plugs:-
Whilst the oil is draining & the engine still hot, its best to remove the coil packs & spark plugs as its easier. I change the spark plugs due to age (every 4yrs), even though they looked ok, showing light deposits of a grey/brown colour indicative of perfect combustion (as shown on the MOT emissions test results). I decided to install the same brand/type of spark plugs as before, Bosch double platinum “Y 5 KPP 332”. The much more expensive NGK “PZKER7B8EGS Laser Platinum” is basically a NGK copy of the Bosch & only a double platinum, even though some web info has it listed as “iridium”. Bosch designed this spark plug & NGK got the specs from Bosch! Remember to use the special VW silicon paste (G-052-565-A1) on the coil pack tips! I also note that the Bosch spark plugs now state made in Germany, whereas my previous set stated made in China!
Cabin Air Filter:-
Previously I have installed the top spec Mann “FreciousPlus” cabin pollen filter as its one of the best on the market. However, I decided not to replace it like for like, & instead fitted the mid-grade Mann “Activated carbon” cabin filter. The bio functional filters like the Mann “FreciousPlus” ideally require changing every year! As I don’t do that much milage, don’t have loads of allergen problems, & don’t live in either a big town or city, I don’t really have the use/cost justification for the fancy bio functional filters!
Gearbox Oil:-
VW doesn’t have a service interval for my gearbox, & therefore its “sealed for life”. However, I prefer to change it & use the old schedule of every 5yrs. Back in 2017 I drained out the factory oil & refilled with Fuchs Titan Sintofluid FE SAE 75w. This time I wanted to try a different oil. My initial choice, Castrol Transmax Manual V 75w80, wasn’t available anywhere in the UK, so I chose Millers Oils Motorsport CRX 75w NT+. This after a conversation with the tech dept at the place I was buying my oil from. I did contact Millers Oils tech dept before I bought the oil & asked them about the oil. They stated they do not send their motorsports oils off to be manufacturer approved & that it has similar characteristics as their VAG approved oil for my gearbox (Millers Oils XF Premium MTF 75w). Officially they don’t recommend the motorsports oils when they make an approved oil, so "use at your own risk" is the legal answer! However, I’ve used their motorsports range of gearbox oils in previous VAG cars with no ill effects, & this oil with the “nanoDrive” is designed to reduce friction in the gearbox, etc., etc. Considering the car is Revo stage 1-B tuned & the MQ250 gearboxes are a known weak link, using the best oil the protect the gearbox makes perfect sense!
Initial observations:- there is less noise in the cabin from the gearbox area, less noise when you really floor it in 3rd gear, & the car freewheels much more when you lift off the accelerator!!
Engine Air Filter:-
I have an ITG drop-in replacement panel filter which is washable. I wash this every two years & it was due this year! I prefer a washable filter, & yes, they take time to wash, dry, & then re-oil. However, they always seem to allow the engine to breath better! On previous cars I have had K&N, & Green Cotton brands, so when I chose a filter for this car, I decided to try ITG, which are based in the UK. The construction of ITG filters is different to both K&N, & Green Cotton, as ITG use a three layered foam, instead of a fabric between two layers of steel mesh. These "trifoam" filters are used in desert racing etc. & are motorsports proven. I have found that they are more "delicate" & require more care when washing them, & the awkwardness of the VAG air box & filter for this engine meant ITG had to make an aluminium plate to support the foam. This necessitating several thin strips of foam to seal the air gaps. These thin strips of foam tend to detach themselves from the aluminium plate when washing the filter!....hence my calling them "delicate"! Black automotive silicone, or gel type superglue suitable for foam, does the trick!
