Is there any codings for replacement from pb battery to lithum bat??
High limit voltage of LiFePo4 battery is about 14.6V
In winter the voltage from alter. is up to around 14.9~15.0V
나의 SM-N935S 의 Tapatalk에서 보냄
I think Wet, agm,efb are not connected as a meaning of the words..I am not certain, but I believe there are three choices for coding under "battery technology": wet, AGM or EFB. Not sure where Lithium best falls between any of those categories, if at all?
Im from rep. Of korea. In winter lower than -10 celcius.. I checked the voltage around 14.8~14.9v I use stock 60ah agm batterySounds high. I get only 13.7 at the most, and that's for seconds, then it settles to 13.6. Where are you located that winter makes a difference? Is your battery very small?
What are you using?...OBD11 or VCDS?....
you have to alter the serial number just to tell the car it has a new battery & I am fairly certain that there is a setting for lithium....
might be called "binary"...
VCDS coding..
VCDS coding required:-
From the Main screen:-
Select Control Module [Select]
[19-CAN Gateway]
Advanced Functions screen:-
[Adaptions-10]
New value choice screen:-
Change the following four channels, inputting the relevant data about the new battery.
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,
IDE03256-MAS06106-Battery adaptation-Battery technology,
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,
VCDS coding..
[19-CAN Gateway]
[Adaptions-10]
Thank you very much.
I want to change battery type.
So the Battery technology looks important.
Do you know the Battery technology list when I enter the inside of the Battery technology channel? Is there LiFepPo4 battery type??
Thx a lot. I will check asap..The list may be different on you countries cars to the list on my car....
anyway that is a Lithium Ion battery...
