Vw golf mk7 coding for LiFePo4 lithum battery
yeock914
Is there any codings for replacement from pb battery to lithum bat??
High limit voltage of LiFePo4 battery is about 14.6V
In winter the voltage from alter. is up to around 14.9~15.0V
나의 SM-N935S 의 Tapatalk에서 보냄
southpawboston
Somerville, MA
I am not certain, but I believe there are three choices for coding under "battery technology": wet, AGM or EFB. Not sure where Lithium best falls between any of those categories, if at all?
The Fed
Old Guys Rule
Florida
Sounds high. I get only 13.7 at the most, and that's for seconds, then it settles to 13.6. Where are you located that winter makes a difference? Is your battery very small?
yeock914
I think Wet, agm,efb are not connected as a meaning of the words..
yeock914
Im from rep. Of korea. In winter lower than -10 celcius.. I checked the voltage around 14.8~14.9v I use stock 60ah agm battery
golfdave
Scotland (U.K.)
MK7 Golf GT Estate
What are you using?...OBD11 or VCDS?....
you have to alter the serial number just to tell the car it has a new battery & I am fairly certain that there is a setting for lithium....
might be called "binary"...
yeock914
I use Vcds..
Could you tell the route to modify the binary? Or the title of the coding in the category number..
golfdave
Scotland (U.K.)
MK7 Golf GT Estate
VCDS coding..
VCDS coding required:-
From the Main screen:-
Select Control Module [Select]
[19-CAN Gateway]
Advanced Functions screen:-
[Adaptions-10]
New value choice screen:-
Change the following four channels, inputting the relevant data about the new battery.
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,
IDE03256-MAS06106-Battery adaptation-Battery technology,
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,
yeock914
VCDS coding..
[19-CAN Gateway]
[Adaptions-10]
VCDS coding..
[19-CAN Gateway]
[Adaptions-10]
Thank you very much.
I want to change battery type.
So the Battery technology looks important.
Do you know the Battery technology list when I enter the inside of the Battery technology channel? Is there LiFepPo4 battery type??
golfdave
Scotland (U.K.)
MK7 Golf GT Estate
The list may be different on you countries cars to the list on my car....
anyway that is a Lithium Ion battery...
Did you ever get this coded correctly? I'm looking to swap to a LiFePo4 battery, but I'm worried about the max charging amperage of the alternator being too high for most LiFePo4 batteries.
