Canecreekfreak
- Boston area
- MK7 GTI sport
Thanks for posting all the info here y'all! Just got the vland tails delivered today, and was a little lost on what to do next. This post is a huge help, so thanks again!!!
Coding is definitely needed. I installed Vlands myself. They come with 7 and 7.5 harnesses and the single yellow wire for the sequential turns. I used @ZERO815 guide for just relocating wires in the harnesses and adding a third wire. I didn’t use the plug and play harness
I can somewhat. It ran from the passenger side to driver side hatch side lights. I will need to find the guide I used to give you the pin outs specifically and update the post.How di
please explain how did you add the third wire & where ?
hi gixxerfool plz find it I'm kinda stuck needing more info before I proceed, it will be much appreciatedI can somewhat. It ran from the passenger side to driver side hatch side lights. I will need to find the guide I used to give you the pin outs specifically and update the post.
Sorry for the delay.hi gixxerfool plz find it I'm kinda stuck needing more info before I proceed, it will be much appreciated
ty
thank you well explained I will try this will out.Sorry for the delay.
You will need a terminal for inner-left body side tail lamp harness. you can source these from TE Connectivity or a supplier of their parts. Here is the VW part number 000-979-025-E for the actual wire. It’s really expensive for one wire, but it’s crimped with the correct terminals already and you can order from whatever VW stockist you would like.
Another option, since you need to remove pin 4 from the outer-left body side harness anyways is to snip it and reuse it for the third wire. if you go this route, I highly recommend you leave enough length in order to splice it back to stock if you want.
On the hatch side of the harness, you will need to locate the inner-right tail lamp harness connector. Pin 4 should be a black and blue wire. You will splice the third wire into this. You don’t disconnect it from the connector, just add on the third wire to it.
Run your new wire in whatever fashion you choose across the hatch to the inner-left body side harness connector. Plug the precrimped terminal end into space 4 which, if you followed the rest of the same guide should be vacant now as that wire is in spot three. So the new order from 1-5 on the inner-left should be:
1-gray black
2-red
3-blue black
4- new third wire from the inner-right
5-empty
This is Zero815’s guide, not mine, but it was the only information I needed to get this done. Mind my scribbling at the top.
hope this helps
