Video playback on CMS.
Thatcher
Wolverhampton
Hi guys,
Having an issue wth video playback through the CMS. I have a iPhone 5s connected through MDI cable with green collar. All else is working fine and the video folders are displayed and I can access a folder called "Video(iPod)" through the media setup screen, from here you can select screen and adjust brightness size and format etc etc. However, I cannot seem to get any videos to display! When I search for any videos through the CMS it says "No playable Files" even though I have purchased videos which should be available. When I play them through my phone but connected to the car, I hear Audio but no visual appears. Just wondering if anyone is experiencing the same issues or if anyone knows how to resolve this? Do I have to change the format of the videos or ? Also does anyone know if there's any way of playing non-purchased videos, I.e ones you have recorded on my phone myself? Any help would be greatly appreciated!
Thanks all
BlueBullet
Great Britain
I tried with green cable and same issues, tried playing movie recorded on phone and that didn't work either. From what I can gather its red cable or nothing at all.
salmon
UK - SE
Yes its the red cable that you need - the part number being 000051446M
I believe the dealer supplies the car with a MDI cable (not sure which colour). I hope I can swap the supplied cable with the red one directly from the dealer.
Thatcher
Wolverhampton
As far as I am aware, the red collared cable is only available for iPhone 4/4s and old generation iPods that use the 30 pin connector. I do not believe that there is a red collared cable available for the iPhone 5s. I have a green collared one for 5s which has the folder option videos, but as of yet I haven't managed to get any to work. Also with the green cable I have managed to access a "screen" option where the videos would be displayed if it was working. I believe the problem in having is that it is not on the correct format for the CMS to recognise the videos where searching through folders on the CMS.
salmon
UK - SE
Apologies Thatcher you are right surrounding the red collared cable - its certainly made for pre iphone 5 phone/touch devices. I have an old iphone 3gs which I will be utiilising.
On the comments you made, could it be the format size of the MP4 you are trying to play? How about using a program like `any video converter` and see if you can change the output size and re-try. I personally doubt a software update from a dealer would fix this.
If I had the vehicle (still on order) I could at least confirm if the red collar cable plays video using an old iphone/ipod touch device.
