Thanks guys for bringing this back up. I had removed torque limiting and ECS, but not the XDS and braking mods. Will tinker!
Hey RM, have you seen an event actually break out VCDS cable and laptop to sustain a protest?
Ok I just got to do some driving and wanted to report back on what these changes do.
Module 03 Adaptations
Hydraulic Brake Assistant (factory set to Normal) I changed to Not Activated
This is very noticeable and allows the driver to modulate brake pressure progressively. As Breaking Badly stated, this is a must do for track or Auto X to prevent the car from apply brakes thinking your are panic stopping or activating the abs.
Brake Booster (factory value set to 4) changed to 5 but did not drive yet.
I tried this at 5 and 6 and just got a softer pedal. I went the other direction and it firmed up at 2, but I currently have it at 1 and it feels great. Better feel and nice and progressive braking force.
Hydraulic Brake Booster has a factory value of 8 and says Offset (not Bais) This setting was very strange. I bumped it up to 10 and apply hard brakes. The car would load up with steady pressure and then after about 1 second it would feel like someone stopped the pedal. There is a surge of brake assist that was delayed and feel really bad. Like the car is recognizing what you are doing and then trying to help. I went back to 8 and let it for now.
25004
11966
15081
18573
20103
24435
25004
28183
31857
37202
40168
44595
10505
25004 works for "Brake booster" adaptation only, from what I remember.
Try 40168 too.
These are all the codes for ABS Brakes that I know of:
Code:25004 11966 15081 18573 20103 24435 25004 28183 31857 37202 40168 44595 10505
