VCDS Advance meas. Values greyed out
geramy1232
Hello, I am having an issue with VCDS because when I go to view the advanced measuring values it is greyed out. I will need this in a couple of days when I will need to adjust the wastegate for an is38 install. Thank you.
BlackT5
Simi Valley CA
2020 GTI SE
VCDS is not compatible with Cobb's consolidated ROM. I want to say Ross-tech was thinking about supporting it so I'd head over there for more information.
geramy1232
So removed ECU tune and it works! Thank you guys for the help never would've though it had anything to do with the tune. Thank you.
shovelhd
Western MA
I went through this yesterday in order to add some VCDS tweaks. I had to download a version 1.x stock tune from Cobb to make it all work, then flash back to EQT.
