VCDS 13-Auto Dist. Reg -- Status: Cannot be reached 0100
Tomstud12
Ireland
Hi,
I just got a VW Golf 7 2013 and the front radar sensor says its unavailable and cruise control doesn't work for me either and so I got it scanned and for one of the modules it says
What could the problem be?
doctor
VAG
Yeah I one of the mechanics said the same thing
Gateway can be. Because if you didn't crash, radar sensor is not a material that is too weak to fail on its own. But any short circuit in the vehicle can easily burn the gateway, because all the hardware is connected to the gateway.
First you can check all fuses,
Good luck
MrBounce
UK
2.0 GTD
I have checked the wires going into the radar and they have voltage and i also disconnected the negative wire from the battery and there was resistance
Hi, how do you access the radar to disconnect the blug to check the voltage please? do you have to remove the bumper (mine is the dome style radar)
