I've been working on my car a lot over the past few days, fixing small issues and sorting out the build.
Yesterday, I removed the vacuum pump, which has been leaking oil on my engine basically since the car was new. The dealership re-sealed it once, but the leak came back worse due to a bad mating surface (you can see in the pic)
I was planning on adding a small bead of high temp RTV gasket maker around the metal seal to hopefully avoid future leaks there.
Unfortunately, I can't for the life of me figure out how to re-seat the vacuum pump! I can get it nearly on, but the small cross-shaped piece hits the cam and prevents me from fully tightening the unit down. Is there a special way to clock the pump so that it pops into place? Getting very frustrated!
