Hi. I've recently found a method on doing a NAR->EU conversion and I got it to work on one car, the one which was the NAV variant. I've got another car, which has the same firmware version as the other one before I did the conversion + upgrade, but it is the PLUS variant. On the first car, upgrading it worked fine (after having messed with the binary), whilst on the other it fails due to the DownloadManager binary being too old:
The original attempts were just trying to upgrade from that 05xx version -> 0635 (NAR) -> 0635 (EU) and that did work on the first car, tried the same procedure on the second (with the appropriate variant of the firmware) but nothing except that error.
I have now tried using the 0631 (EU) version, but that still has got the same requirement. I have also checked, and the NAV variant doesn't have any requirement for the DownloadManager version.
I tried using the DownloadManager from the other car, even if it was basically completely different in terms of bytecode, and that resulted in it almost working but failing to read the metadata of the actual, specific update. Tried it with EU 0635, no change.
If you've got any ideas, please let me know. I just need to upgrade it to the next major version (06xx) and I can do everything from there. If someone has got a P06xxD, PLUS variant, if you could please send your DownloadManager binary it'd be of great use.
Code:
The version of DOWNLOAD MANAGER:(554) is not compatible with the version requested by metafile(600)
