Chapstick
- Grafenwöhr germany
- 2019 golf gti
I was just curious on any recommendation on coil overs what works best and what doesn’t work I have a 2019 golf gti and I want it lowered about 2-4 inches
between 500- 1500What is your budget?
Okay thank you to be honest I’m new to mods I just know I want it to be lower then it is and I want something that’ll be worth it , and bags are definitely out of the budget2-4 inches is ALOT. I don't think 4 is possible without bags and even then that's a stretch.
I have the ST X Coilover set. If I could do it again I would purchase the ST XA so I could adjust the camber. Otherwise, ST X runs pretty well no rubbing (Michelin PS4S) with 18" Austins and stock tire size.between 500- 1500
You could swap springs for $200-$300 plus labor. But that will get you anywhere from 0.5" to 1.6", depending on brand. Stock shocks and struts will deteriorate faster than normal.between 500- 1500
I would choose either BC racing coilovers or broadway statics. Promise you wont be disappointed with eitherbetween 500- 1500
