BTFPTM
- Frankfurt Germany
I do stay at the Holiday Inn Express once in a while.
Might not be a joke you understand as it might be only a USA commercial.
I certainly do know this joke, I may live in Germany and speak german but I'm as American as apple pie and the president's epic hair-do. I've even stayed at a few Holiday Inn Expresses myself
Thanks for the continued feed-back, guys!
It's also good to hear someone else chime in who has a similar problem. And yes, it is damned freaky at 200kmh when the nose starts pulling left and right. If this is actually a result of the electronics that are supposed to improve stability, whatever engineer programmed this needs to be beat with his own Birkenstocks.
I'll do the tie rods as I have time, and I'll work with lower pressures and see if it helps. And as someone else also mentioned, I have in fact had the feeling that the tail seems to float, so maybe that'll solve that one, too.
I had first suspected a sticking caliper, too, as someone also mentioned, which is why after I did the rotors and pads I had VW do a complete flush and bleed of the system to rule that out. The new parts did make the problem less extreme, but didn't eliminate it completely, same as with the tires.
Thanks again, guys, I'll keep workin on it and report back.
