Tacomonster
- Colorado
- Gti 2019
Does anyone know how to unlock the windows feature where you can roll up/down windows via the keyfob? I have seen it youtube but don't know how to get this feature access.
Would a dealer be able to do this?
Yes. But will they without charging for it? The easiest cheapest way is to buy a $15-20 OBD2 dongle on Amazon and buy one weeks usage of Carista for $9.99. Make all the changes you want beside the one that you want. Or just buy OBDeleven for around $60. A dealer would charge you more for just that one change than buying Carista or OBDeleven and then you can make lots of changes.
idk how much diy you do but OBDeleven pro) is about 60/70 bux. worth it for stuff like this. I turned on factory alarm, adjust mpg readings/comfort blink, numerous window features (ie active for 10 minutes after you open door) not a huge investment but a good return.
Don't they come with factory alarm on?idk how much diy you do but OBDeleven pro) is about 60/70 bux. worth it for stuff like this. I turned on factory alarm, adjust mpg readings/comfort blink, numerous window features (ie active for 10 minutes after you open door) not a huge investment but a good return.
I’m new to the vw family and I have a lot to learn. Is there a difference between obd 11 vs vag com vs carista? I have a generic obs2 That I had used on an old Subaru with the obd fusion app on IOS, would I be able to do it with the generic reader?
