Unitronic IS38 Boost Level?
ZuMBLe
NY
Alltrack 6MT
I keep 2 5-gal jugs at home and that's what I do - just splash it in as needed. I fill up to ~2 gal under then top off typically. We have E a few places within 30 min so getting 10 gal once in a while isn't any drama.
I have a gas station 2 blocks from my apartment; but I travel about 30 min for good E also. I would be in heaven if my local gas station had E.
tigeo
We have several choices but all are Sheetz stations. There are 3 within about the same distance from my house and one is on my way to/from one of my client's office. I need to test it at some point but some of the local corn boi roll racers have tested it and it always tests over 80%
ZuMBLe
NY
Alltrack 6MT
Def test it. I've had one station go from 70 percent to 55 percent! I now just use one station that is 80 all around.
OBP
ChiRaq
You have logs? Mind posting them?
The 1.8 has smaller injectors and uses a lower pressure HPFP vs the R or GTi and some of those do show rail pressure drop.
