Replaced manifold due to 2015 code. Cleaned the valves as well. New injector seals. Triple checked my connections. Car pulls/drives without issue. When I shift to neutral and coast/idle, the revs hang, then drop to 800. It bounces between 800 and 1200 for a few minutes, before finally dropping to 600 and idling smoothly. (600 was idle speed before swap). Got a 0171 code and a 0507, but they didn’t come back after clearing. 90% sure it’s an air leak, but I don’t see anything obvious. Has a catch can installed, so no pcv. Diverter valve is rev D, didn’t see any issue with it either. K04 with a Unitronic DV relocation, all hoses clamped tight. Intake and turbo coupler also look secure. I definitely reconnected all vacuum lines I disconnected for manifold replacement. Anywhere else I should look before going for a smoke test?
