I'm not familiar with how it transitions into the turbo.
Basically the main difference between the Epman or Unitronic TIPs (which hurt vacuum, but not completely throwing it out the window like the BMS did) is that they have a smooth transition into the compressor housing. Whereas the BMS (and the CTS V2 which tested very low peak TIP vacuum levels with a gauge).
I don't think that vacuum level is directly correlated to airflow but moreso the port location and transition into the compressor housing. I PREDICT that the parts with a large dia and then necks down into the compressor (with the PCV on the large diameter portion) are more likely to give less vacuum on the TIP.
Look at Jeff's testing of outright flow on the things I've at least gotten TIP vacuum levels on...
https://mygolfmk7.com/turbo-inlet-pipe/
It goes Stock > APR > CTS Cast (V2) > BMS in order of flow.
Based on this (which was determined that the gauge is pretty damn close to accurate with all OTHER configurations later on when I fitted the PCV sensor):
https://www.datadrivenmqb.com/drivetrain/venturicrankcasetesting
The most the CTS V2 (granted, with an intake as well) ever pulled was -0.48psi at it's peak. Based on the difference of me testing with OEM TIP + airbox vs OEM TIP bare (with no filter or tube or anything), there could be another 0.6psi of negative pressure AT THE MOST. So we'll call it -1psi at best.
Whereas the Unitronic pulled -1.8psi at peak, and the Epman pulled -2.2psi at it's peak.
Obviously this is a bit of a stretch, assuming APR = Epman... but in order of vacuum:
Stock > Epman/APR > Unitronic > CTS Cast (V2)
So the CTS flows less than the Unitronic, AND produces less vacuum.
And of course people on the FB pages and stuff are acting like the sky is falling as predicted. Bottom line for anyone not tracking their cars, this will largely never show up as a real problem. Just wanted to make people aware of how to go about fixing their problems... rather than throwing junk PCV plates at them.
