Unable to remove Instrument Cluster
ncsteinb
Saginaw, MI
I am having the hardest time removing this gauge cluster... I've removed the black trim around the cluster and the 2 screws at the bottom, but this thing will not budge... I've tried pulling rather hard, but nothing...
Any suggestions??
carbon_gecko
texas
2016 GOLf tsi 'S'
I had the same issue. It is a PITA but yank really hard.
2018gti
Boston, MA, USA
Golf GTI Autobahn MT
So, I found this thread from Google after struggling to get the cluster out (and failing). I wanted to share my funny shortcut to getting it out. Instead of trying to pull the cluster out of the metal clips, I ended up squeezing the top and bottom of the metal clips with a flathead so they would separate from the dashboard and the cluster practically flew out. So fast in fact that one of the 4 posts on it broke off.. (that’s in addition to the 2 edges of the cluster that I, uh, also broke off 😬)
Hope that may help someone in the future. If you’re more careful than I am you should be able to get it out pretty easy and with no damage.
BTgolfR
Seattle
Golf R
I just used a trim removal hook, hooked it to the back of the cluster on each corner and pulled hard af on each corner at a time.
2018gti
Boston, MA, USA
yup that sounds like the way to do it. there wasn’t a lot of critical thinking happening at the time for me.
fortunately the glue that I used worked well to reattach the couple of edges.
