moarhorsepower
- New Jersey
- Mustang GT, Golf R
Do you know which part# is the original mounting bolt (for the sub but no spare)? Need to buy the right one soon. I assume its 1K0-803-899-D but wanted to confirm.
Has anyone checked their Rabbit models to see if anything is pre-wired?
Sent from my SM-G965U using Tapatalk
This! Please report back if you find anything out.
What I did with feet removal for spare tire:
Rather than just removing them I re-attached them with the screws 3" in from the outer edge. This keeps them if you ever want to set it down and will fit inside the rim of the spare. It will also help keep the sub centered on the spare. You do have to shift feet around slightly to clear speakers but it ain't rocket science. I filled the old screw holes with small 3/4" screws just because I had some.
Instead of disconnecting battery to kill power to the head unit pull the 20 amp fuse located behind coin bin by drivers knee/steering wheel. Top row 3rd from right.
Mud
Mine was like that when I had the sub on top of the spare tire.Interestingly enough my floor cover does not sit flush but is slightly elevated. Anyone else found this to be the case?
