Turn off radio with ignition vs. door open
BodegaBay
Just finished watching Fast&Fuzzynuts
NV
2019 Golf R
Wondering the same thing. Can this be done in VCDS?
Pbrowne
Clarke County, Virginia, USA
2021 GTI
I figured out how I set it this way. Using VCDS go to Central Electronics and look for "funk" in the adaptation settings. That's the German word for radio. Use Google translate to find the right setting.
BodegaBay
NV
2019 Golf R
@Pbrowne I still unsure which "funk" to use. Can you tell me which adaptation settings you used?
Geomets
South-Eastern Europe
Golf mk7 GTI
When I turn off the ignition, the radio stays on until I open the driver's door. How can I get the radio to turn off when I turn off the ignition?
Maybe you should retract the key? Mine works this way. I can't recall what happens when I open the door, I usually turn everything off before I get out of the car.
