Turn off amber indicator light (US)
Leo ATX
US
'21 Mk7.5 GTI
What should I take to turn off the amber indicator light on US spec models? This is regarding the amber indicator light, not the amber reflector strip.
Right now it looks like the only option to me is VCDS.
Clem604
Vancouver BC, Canada
2018 VW GTI
Right now it looks like the only option to me is VCDS.View attachment 204412
You can do it with OBD11 or VCDS although I don't remember the exact coding changes. I have mine turned off.
bobloblawGTI
DC
19 GTI SE 6MT
With OBD11 or VCDS:
09 - Central Electrics
16 - Security code 31347
10 - Adaptations
Leuchte26NSL LA72
"Lasttyp 26" set to “not active” (default: “43-allgemeine LED”)
If you want to disable the tail light side markers also, it's:
10 - Adaptations
Leuchte27NSL RC6
"Lasttyp 27" set to “not active” (default: “43-allgemeine LED”)
PenIsland
New jersey
Volkswagen GTI 2020
With OBD11 or VCDS:
10 - Adaptations
Leuchte26NSL LA72
10 - Adaptations
Leuchte27NSL RC6
What do the front and rear light markers do? They don't flash with the turn signal, right?
bobloblawGTI
DC
19 GTI SE 6MT
No, they don't "do" anything except stay illuminated when the headlights are on due to U.S. DoT regulations. I could be wrong but afaik they aren't even present on non-NAR vehicles.
greekspec2
California
17 Golf R 17 BMW X1M
the correct way on a MK7 at least is to remove the wire from pin T14j/13 & T14k/13, if you do the coding it turns off the center position lamp led M1 & M3 in the high beam light.
bobloblawGTI
DC
19 GTI SE 6MT
I don't know if it's different for the Mk7, but I just tested on my Mk7.5 and the coding change didn't affect any part of the lighting system except for the amber side marker. Tested with DRLs, low beams, and high beams flipping the bits back and forth while looking at the LP assembly.
greekspec2
California
not sure on a MK7.5 but if you use coding on a MK7 it will turn off the center led and the N/A side marker led hence unpin the wires.
Gr33nBunny
610-SePa
18 GTI SE 6mt
One of the first things I did upon receiving my OBD11 was screw up all my lights, then figured out how to fix it, then disabled the amber sidemarker up front and the red in the rear. So much cleaner without them
chillax
Wi
18 GTI SE plaid
If you can find a pic would you point out the rear one? I'm not sure what you are referring to.
Gr33nBunny
610-SePa
18 GTI SE 6mt
Thanks, I think I'm going to disable the ambers but leave the back ones for now.
I definitely think getting rid of the amber makes more of a difference than than the red, but I also have decal overlays so basically no amber is visible on my front end unless the blinkers are on.
And hey, nice combo trim. SE with plaids ftw!
