What Kool-aid is this you speak of? I hope you don't think I'm some kind of APR fan-boi. I have never owned any of their products. But I do think they produce some really good ones. With proper research and engineering behind them.
Back on point..
Have you ever seen a CFD (Computational Fluid Dynamics) model of airflow thru a 90 degree bend in a pipe? Its crap! The airflow does not just flow thru the bend, it slams in to the far wall of the pipe creating a high pressure area and starts to tumble. The near side, by the smaller radius of the bend (inside of the elbow) will have a low pressure area. Then all of the aftermarket TIPs I have seen closeup pics of have a reducer or bellmouth to meet up with the turbo inlet. So.. take all of this turbulent, chaotic airflow with different pressures and velocities, cram it thru a reducer and present it to your compressor. Everything I have learned and observed about airflow into a compressor (Axial or centrifugal flow, Turbo, Centrifugal supercharger, APU, ACM Jet engine) is that they, to operate at the highest efficiency, need clean non turbulent high velocity airflow entering them. The average aftermarket 90 degree welded tube elbow can at best provide only a slightly higher volume of air. While throwing out every characteristic that the turbo actually needs to gain it. The factory designed the stock piece with efficiency in mind, and in this case efficiency= performance. We all know how the auto industry chases every ounce of it in their designs. Look at the stock TIP, Its not really a 90 deg bend, its more like 2 45s with a slight curve in the middle and a constantly reducing ID. The compound curve along its length smooth the airflow and the reducing ID keep velocity up. Now look at the APR piece (or the TTE or LOBA ones). Very similar design to the stock piece, keeping all the features the turbo needs to be efficient AND increasing volume (CFM) over the stock piece. So far APR is the only one on the market even worth looking at. Of course all this is IMO... And if anyone with a engineering background wants to correct me, feel free.. I'm always up for learning something new.
