Turbo flutter because of unplugged DV safe?
riceburner
nice try PPNT
MK5 Best GTI
Which aftermarket dvs allow adjustment for flutter?
Jovian
Denver, CO
2016 VW GTI
Correct me if im wrong but I dont think turbo flutter is something you should strive for. Its ok to have a little under extreme situations but its in general not a healthy thing for the turbo.
Are we talking about actual turbo flutter or just DV valve releasing boost pressure?
Supercrumpet
Georgia/South Carolina
'19 Alltrack SE 6MT
tigeo
To the question about which aftermarket DV/BOV allow adjustment. Suppose it a big rigged to get it that way but he's using a GFB response valve (is this the same as the DVX?) and making a slight adjustment/mod to be able to get some flutter (adj to block off the recirc side and then set to recric) vs. discharge to atm:
tigeo
questions of the hour right, lol.
answer is both... some are taking about flutter
For sure during these discussions there is often quite a bit of confusion on how this all works - flutter vs. blow-off to atm vs. recirc.
tmw2442
Mk7 R
