TTRS Brembo Upgrade Info
El_bigote_AJ
Las Vegas
2019 GTI bunny
Not much room in there…
Does anyone run the little noise damper things on their calipers?
I do, I forgot them on the pass side the first trip and didn’t really notice any difference in noise… but also it’s was a short trip🤷🏼‍♂️
Considering audi added these with the provisions as a fix I’d assume they are effective though cause I’d assume some R&D $$ was spent
MiamiBourne
South Florida
2016 6MT Golf R Oryx
These look so good. I'm almost ready to offer the seller what you did. Lol
I wonder if my 19" Pretoria's w/the current 10mm spacer would fit. I used to run 15mm spacers up front but when I switched from PZeros to PS4S I was worried the slightly thicker Michelin would rub...
krs
Las Vegas, NV
MKVIIS R
The kit was complete, all the way down to the new rotor screw. For the price I’m happy with the product, but wouldn’t have wanted to pay much more.
krs
Las Vegas, NV
MKVIIS R
Yeah, this is true. I’ll probably put them on after I check everything in a few days.
MiamiBourne
South Florida
The only thing I would need are the TTRS brake lines correct? If I wanted let's say Neuspeed SS lines, I would just shop for the MK2 TTRS lines on their site?
Also the stock heat shield can work with modification, correct? Either way the TTRS heat shields don't seem like they cost that much and I would probably get them.
swcrow
7.5 GTI
a lot of modifcation.....like cutting...not bending or shaving...cutting.
scrllock
MI
No, you need the Mk7 chassis end and mounting tabs (not sure what to call them, they help attach the line to the knuckle so it doesn't rub). Neuspeed will sell them though, just email and ask.
Stock heat shields can certainly be used, but it requires some cutting and future you will really appreciate it if you grind down the sharp edges. The 8V/8S shields require no cutting, just mild bending.
MiamiBourne
South Florida
Thanks! Adding the heat shields to my list!
After posting, I went back to read the first page and now realize I do need a modified brake line. Thanks for the clarification also.
krs
Las Vegas, NV
MKVIIS R
Yeah I only had to do some minor trimming on the passenger gear shield. Think they were less than $40 ea from E-ACCA.
The brake lines are essentially very similar to the RS3. I just called neuspeed, told them my setup, and they made them and shipped that day. I also swapped my rear lines, just because.
MiamiBourne
South Florida
Thanks…rear lines. Why not. I’ll add those also. Lol
krs
Las Vegas, NV
MKVIIS R
if you are using the RS3 shields you have to replace the passenger brake line bracket with 8V0611842
Was easier for me to trim the shield, which really wasn’t much. From there I rolled the edges over so it wasn’t sharp. The user has options, just depends on what they want.
