If anyone's looking, there's a set for sale on FB: https://www.facebook.com/marketplace/item/496118675493903
Replacing a bleeder is trivial, good deal.
No, I just gave them my order number. They have to assume the old ones are faulty, there's no reason to want them back.Don't they also say you gotta send back the old pair? I just put my ttrs on in may
I'm using the 370x32mm 8J spec. I was asking Girodisc about pads and they said they only really sell/recommend the 14-15mm thick pads (e.g. 3067).That is interesting that the 1334's didn't fit. I don't recall if you're using a 32mm or 34mm thick rotor. I had the same issues but I was using the 34mm rotor.
I'm finding at the small michigan tracks they're passable. I'm sure it's a different story at the high speed southern tracks. Not looking forward to the cost of DS1.11I've done 2 tracks with the TTRS Calipers and DS2500s. At Autobahn South they're great. At Road America I probably needed a different compound. Got a little bit of a long pedal during my second session. I run RBF660 and I didn't bleed between days so YMMV but those we my observations.
I didn't end up replacing the pistons, was going to trash the originals and upgrade later, but looking at the pictures I just took of my calipers the part number is 20.4872.48 44mm seal. https://www.ecstuning.com/b-brembo-...tJBwvbem_hse1wylH3ExrKS_bChpWpzgaAt9tEALw_wcB@MrFabulous would you mind sharing the p/n on the brembo dust boots you used?
Yeah, these are a newer model too with their “best brake clearance” currently - so I’m sure most of the other ones gonna hit real bad without a spacer!I was worried about that with most of the konigs. So far my neuspeed/apex wheels have all cleared with plenty of room.
