I recently picked up a set of these calipers and wanted to share the info I've gathered in the process. None of it was consolidated (that I could find!) so hopefully this helps someone else. I was able to pick up a set for $600 shipped including pads and lines, and after a rebuild + powdercoat I'm still at less than $1000. YMMV. I look forward to testing them on track next season. The part numbers mentioned for rebuilds, hardware, etc. are all ones I've confirmed. Should I hear otherwise, this post will be updated.
Calipers
Current P/N:
8J0-615-107-B
8J0-615-108-B
Old:
8J0-615-107-A, 8J0-615-108-A, 8J0-615-107, 8J0-615-108
These were stock on Mk2 (8J) TTRS fronts (2012-2013 for NA?). 4-piston Brembos, mounted in a leading position, and bolt directly onto MQB hubs. Other non-mk7 golf fitments include: MK5 Golf/Jetta/GTI/R32, MK6 Golf/Jetta/GTI/Golf R, VW Tiguan/ Passat B6/B7 / CC, Audi A3/S3 (8P/8V), Audi TT (8J/8S).
They are top-loading and allow for quick pad changes. The current revision added harmonic dampers on the inner side to combat NVH. Reportedly the noise this was intended to combat can be remedied by using aftermarket pads, and you'd save weight and cost if you can find the original parts used.
Internals
Pistons are 40/44mm diameter (30mm deep), which works out to slightly less than stock piston volume accounting for the movement of fixed vs. floating calipers. I ordered vented ones from RB, but if someone has a brembo/centric p/n I'll add it here.
https://racingbrake.com/bc-41p
Seals and dust boots are a standard centric p/n:
143.03005
The pad retaining hardware are another:
117.33035
Carriers + Lines
The easiest option is to buy the VBT kit, which provides lines and alternative carriers and hardware to use 340/345mm rotors:
https://www.vagbremtechnic.com/fron...mbo-calipers-to-oe-340-or-345mm-discs-ak0003/
If for some reason you come across a set without the original carrier, want to use 370mm rotors and can actually find some for sale, the original carrier p/n is:
20.9747.61
The stock carrier->caliper bolts aren't sold by audi either, but are available with a porsche p/n:
99907340201. Torque to 110 N-m.
To bolt the carriers to the hub, use your stock VW bolts and torque spec, TTRS bolts are the wrong length.
For lines I would suggest the VBT kit (they'll sell the lines separately, just a Hel kit), buy SS TTRS lines and figure out the brackets (not a complete bolt-on option) or have someone make you custom lines, just ask for Mk7 lines with TTRS ends.
Pads
An advantage shared with the macan caliper is the pad shape, FMSI#
D1001, Pagid
2487, Ferodo
FCP1334H/
FRP3067H, Endless
EIP184 and others can be found via cross-reference. The VBT listing has a decent set of part numbers available to bundle.
One difference I've found is that the p/n for the Evo (Ferodo FRP3067H) is about 1mm thicker than the STI one (FCP1334H). I don't yet know if the thicker ones are 100% plug 'n play, but you can always have a pad sanded down.
I'm personally a big fan of DS2500, which FCP stocks in the thinner spec:
https://www.fcpeuro.com/products/audi-vw-performance-brake-pad-set-ferodo-racing-8j0698151k
Zeckhausen has a good selection here too:
https://www.zeckhausen.com/catalog/index.php?cPath=44_749_750_5215_5218
Not cheap, but they work very well and you get lifetime replacement. I know they work well on my RB rotors without deposits or squealing.
Rotors
As mentioned, the easiest option will be the VBT kit if you already have 340/345mm rotors. No need to recommend options for those here.
With the stock carrier, you can use the stock rotors (370x32mm). Unfortunately, Audi only produced one part and so the vanes go the wrong direction on one side. For some people this resulted in issues with warping with hard use. They're also drilled which can be a downside. You can
not use the Mk3/facelift (2017+) RS3/TTRS rotors
nor the Neuspeed 370x34mm rotors.
https://www.fcpeuro.com/products/audi-vw-brake-disc-zimmermann-8j0615301k
There are a few properly symmetric, slotted 2-piece options:
Girodisc:
https://www.girodisc.com/TT-RS-8J_c_1351.html
Reyland (don't ship to North America):
http://www.reyland.co.uk/audi-front/
PFC:
https://pfc.parts/product/370-496-63-64/
RB:
https://racingbrake.com/2439 (includes spacer to use 380mm discs)
Girodisc seem to be the most popular and are definitely the cheapest 2-piece option available in NA. PFC makes great stuff but with freight shipping from the UK they came out to around $1650/pr. I know people swear by AP J-hooks and I could swear I saw a 380mm AP disc with a spacer, but haven't dug it back up yet.
Heat shields
8V0-615-311-B
8V0-615-312-B
8V RS3/8S TTRS heat shields are bolt-on fitment for our 57.1mm hubs. You might need to hammer out part of the lower section that comes close to the bottom piston. They should fit any of the rotor options (will confirm for 340mm soon).
You should be able to use your stock shields as well with some trimming, or remove them entirely depending on your usage. RS3 control arm ducts would certainly help, too.
TTRS vs. Macan
I'm sure this will be asked since these are very similar to the Porsche MLB chassis caliper option. I'm only giving facts, make your own decision.
- Cost: TTRS are $1800+ new just for the calipers, compared to about $500 new for a pair of Porsche. I got lucky on FB marketplace finding mine for $600 shipped with lines. They were in terrible shape and needed a rebuild, which I spent about $500 on including new pistons, seals, boots, bleeders, sandblasting, and powdercoating. For most people, cost alone is a non-starter.
- Pistons: They're very close in overall piston area, and we know that some Mk7s (Mk7.5 R?) came with the same-sized M/C as the 8J TTRS (25.4mm). However, the TTRS brembos come in 40/44 configuration vs the 42/42 of the porsche. Per @Will_ / @burgerkong , the Macans have different pistons on each side, possibly to help alleviate the uneven wear this could produce?
- Leading vs. Trailing: Porsche are a trailing design (mount to the rear of the rotor) vs the leading design of the TTRS. You thus have to flip the porsche to mount on an MQB car. Unclear if flipping the pistons helps at all given the difference between each side.
- Carrier: The carrier on the Porsche is part of the caliper itself. This is likely more rigid, and definitely simpler. No bolts to fail/improperly install. You're also limited to the smaller rotors with porsche (though of course anything is possible with fabrication or spacers). Both allow you to save on rotor costs but the TTRS option does let you upsize down the line if you overwhelm the heat capacity of the smaller discs.
- Weight: I don't have the TTRS brembos in front of me, once I have them back in hand I will weigh both the Macan and TTRS with their respective hardware and lines. Both are significantly lighter than stock PP calipers.
- Wheel fitment: If you know that a wheel fits the Mk2 TTRS, you know it'll fit these even with the 370mm rotors. I believe the fitment templates in the Macan thread are incorrect, and I haven't seen a template for the TTRS calipers with a VBT adapter. Looking at them side by side, they're likely very similar in barrel/spoke clearance. Neuspeed told me most of their 18"+ wheels will fit the 370mm TTRS setup, and I would guess that the 18" Apex wheels are likely to clear, especially with a 340mm setup. If I can verify certain wheels I will try to add them to this post. Apex promises fitment for for Macan calipers.
My guess is that the TTRS calipers are
probably better on track due to the piston design and ability to run larger rotors. I'm sure that a proper Stoptech/AP kit is by far the
best option and I'm sure that my novice driving doesn't even demand the rotors on my car, much less any of these calipers or the track-only pads I'll be swapping. If I somehow get the motivation to install the Macan calipers AND these, I would love to give a comparison on pedal feel between the two on the same brake pad, but I'm sure this is fairly subjective and will depend on how well your fluid is bled, your specific ABS module tweaks, and your choice of pads.
I will say that these are definitely proven and I've never seen anyone need to deal with extra greasing, RPVs, or worry about not using SRF. Once you've rebuilt them they should be up to par with any of the nearly identical Evo/STI brake setups out there.
Hopefully someone finds some of this info helpful, though I'm sure most people will prefer the cheaper Macan setup or a not-much-more-expensive true BBK.
