Is this a modified IS38?
Read TTE recommends changing valve springs.
Found this
http://www.audi-sport.net/xf/thread...-s1-s3-8v-tts-cupra-sc-5f-octavia-vrs.261889/
TTE525R Performance Upgrade Turbocharger
GOLF R & GTI MK 7 / AUDI S3 8V / LEON CUPRA & SC 5F / SKODA OCTAVIA vRS 5E
TTE525 is our latest hybrid performance upgrade turbocharger for the new 3rd generation VAG 2.0TSI following on from our proven TTE450+ (TTE470) upgrade stage. Stage 3 power, same stock turbocharger spool and response.
Engineered & Enhanced
To construct a TTE525R we change the original compressor and employ a far larger and more efficient billet wheel with extended tip technology and mill the compressor cover to optimum gap to match the new compressor profile. We CNC mill the turbine housing and install a larger clipped and lightened turbine for greater gas flow. We CNC modify original compressor cover, for increased airflow. We replace the original recirculation solenoid valve with a Motorsport atmospheric blow-off valve that's included in the price.
We also fit our TTE CNC silencer delete. Modifying the turbo discharge silencer, removing the baffle internals and fitting a new straight through section, removing any restriction and its function as a noise cancelling device, and so improving the flow, giving less surge and enhancing the sound.
The clipping of the turbine is a special TTE grinding process to the turbine blade tips. Curved to alleviate stress from process. Clipping reduces blade area thus increasing gas flow and so reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost level. This process also gives a secondary advantage of removing some material, lightening a allready lightened turbine thus reducing rotational mass improving moment of inertia, meaning fast spool up.
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
Key Points
TTE Oversize Latest billet compressor geometry
TTE Oversize turbine/shaft, lightened and clipped
TTE Oversize turbo intake
Genuine IHI CNC modified housings
CNC Optimised modified TTE silencer discharge delete
Motorsport BOV
Optimized clearances
Plug and Play installation
We offer brand new or we also can offer to recondition and upgrade your used turbocharger
Single parts finely balanced then components assembled and core high-speed VSR balanced, supplied with a balance test result document
550PS Capable
Designed, Machined & Built by TTE in Germany
Brand new Price is 3499.00 euro inc VAT
Reconditioned and upgraded used Price is 2449.00 Euro inc VAT (from a Golf r type turbo size)
Shipping does vary but 45.00 euro is a good guide for Europe wide.
(for non EU countries 19% VAT can be deducted)
Reconditioning price shown is based on overhauling and reconditioning, upgrading a undamaged used as new turbocharger within specification. Only once cleaned and dismantled, inspected then a firm price be made.
