trw pads ghost?
fabr
arroyo grande
2019 golf R
hello
went through old post and found guys asking for low dust pads for golf R along with nice grabbing power daily driver and occasional spirited driving
it seems TRW TPC 1633 FRONT AND TRW TPS 1761 REAR should be the way to go to reduce dust and have a nice linear stopping @ fair price
tried to buy , but nobody has em. any advice where to find em? thank you
Mk7gtifl
Orlando, FL
FCP euro had them for my S3 last month, but went with the isweep 1500 instead, guess what, still dust, less than oew but still, don’t know about stopping power but if I had to do it again I will get the TRW and save almost $200
fabr
arroyo grande
2019 golf R
this is what i heard about isweep. but apparently FCP don t have anymore. i tried. thanks anyway
fabr
arroyo grande
2019 golf R
i have found the front trw pads.
TXH 1633 (new code) from FCP under audi
now looking for some good rear pads low dust
imthanick_a
Ohio
I've been running Centric posiquiet pads and they are great. They squeal a tiny bit under light pedal pressure but the dust is super low and they stop HARD
snamtrac
PA
I see these are semi-metallic and no longer ceramic. I reached to TRW to see if they discontinued the TFC1633's.
MiamiBourne
New York
Wow...A friend of mine just installed these based on my recommendation. I didn't notice the change from TPC1633 to TXH1633. I ordered my TRW Ceramics from FCP euro and when I clicked on the link to the original ceramics on my order the new number comes up so I thought it was the same but they are using the OEM part number I guess of 8V068151C
Confusing indeed...
GolfRRRR1
Michigan
https://www.golfmk7.com/forums/inde...p-brake-pads-w-less-dust-thread.357406/page-3
Here's a report on the TFC1633s.
Tl;dr they apparently feel better than OEM with a linear braking behavior, with 40-45% less dust. But mentions that there are probably better options out there.
That was my post. I've had these TPC1633 TRW pads on since that post and I would say the dust is more like 70-80% less than stock...especially since brake-in (when they dusted a bit more). The pads are great for 90% of what you need in a pad, still highly recommend no matter what part number they call them now! Oh and btw, they are good for about 1.5 laps on a race track LOL
MiamiBourne
New York
The problem is the new part number is not the same ceramic pad. They new number is like the OEM pad which dusts a bit more with less fade of course. But it's essentially the OEM pad. It seems the ceramic TRW's are no longer offered...at least for now...
GolfRRRR1
Michigan
Just got off the phone with TRW (ZF) and they are still making the TPC1633, BUT they also have an upgraded formulation which is the TXH1633 which is an ultra low metallic formulation offering a little more bite than the TPC and a little more performance albeit with slightly more dust. I think I'm gonna pull the trigger on them as they are only $40.95 at ECS Tuning.
The part number 8V068151C is a different formulation than the TPC and TXH (which are aftermarket TRW parts) it was designed for the manufacturer and it is a low-metallic pad...not ultra low like the TXH pad. So it should dust more than the TXH and TPC pads but better than OG OEM Golf R pads.
Hope this helps folks picking OEM fitment brake pads at a good reasonable price.
MiamiBourne
New York
The part number 8V068151C is a different if formulation than the TPC and TXH (which are aftermarket TRW parts) it was designed for the manufacturer and it is a low-metallic pad...not ultra low like the TXH pad. So it should dust more than the TXH and TPC pads but better than OG OEM Golf R pads.
Where can you get the TPC because I don’t see them available. My friend got the TXH and he’s not happy with the dust.
GolfRRRR1
Michigan
Do you know how long he has had the pads? They all dust more at break-in. As for the TPC pads, there is stock at TRW, places need to order them to get them in stock (FCP Euro, ECS tuning and others), I'd reach out and have them get ordered.
MiamiBourne
New York
I will have to ask him now as he's put a few thousand miles on them since I installed them. Though initial he said they dusted the same as stock. We just came back from a trip to NC to hit the Tail of the Dragon, Cherohala Skyway and Clingman's Dome so they are pretty broken in by now. Great fun and I luckily had the smarts to remove the TRW TPC's in favor of Ferodo DS2500's for those spirited drives.
That said, when I went into my order history of when I bought my ceramic TRW TPC1633's the link takes you to the TRW THX1633's. Also when you click on the 1 review for these...it's the TPC that's referenced in the review. Here is where I got confused when I shared the link to my friend who thought, we thought, these were the same pads. I had to double check my link as the description did seem different since it didn't mentioned these being ceramic and I saw 1633 but I didn't notice the THX vs TPC difference at the time.
Here is a link to FCP:
https://www.fcpeuro.com/products/vw-brake-pad-set-trw-8v0698151c
I don't need pads now and I guess it's up to my friend to follow up if FCP is going to stock these.
