Track use coilovers
Gvazquez
North Carolina
What's everyone using for track day coilovers? I'm running BCs right now but I'm not certain they will behave well in 25 min sessions. Just list your setup and what you like about them for people conflicted on actual track day coilovers.
jmason
Frederick, MD
Bilstein PSS10. I like the easy adjustability. I can change from street setting (max soft) to front/rear track setting at the same time I install/remove my track tires. Just turn a knob. There are more setting levels than I need. Big downside is that I couldn't get replacement parts. And I wasn't even trying to get a warranty replacement, just straight up buying a replacement strut. Bilstein said no. Had to get a complete replacement set!:mad::mad: I was very tempted not to go Bilstein again, but couldn't come up with a suitable substitute that met my needs and budget.
UroTuning
GolfMK6 Official Vendor
Tampa, FL
Ohlins is going to be the best option for track use. We are a vendor for them and can definitely help you find the right set for your car.
Navi
BK/NYC/Hamptons
I'm on Bilstein PSS10 and they are decent. I would say a little more for spirited driving than track but they would suffice. I have two friends using Ohlins and that's the route I'm going to end up going. They have nothing but good things to say.
AST and JRZ both have interesting offerings out there for track set up. There is also a Moton setup.
Navi
BK/NYC/Hamptons
top dog AST's are hella of a lot more than ohlins price wise. Not sure about performance wise though. Never owned a set. But I know a lot of track bmw guys run them.
Gvazquez
North Carolina
Sweet I see a lot of good options on here. I was really interested in the ast coilovers because of the true coilover rear function and being able to utilize your spring rate in the rear. Ohlins look like a really good option but I would need to budget for different springs since I dont think they lower a whole lot and come very soft. The top dog ast are over 5k lol definitely dont wanna spend that much
Gvazquez
North Carolina
I also found a couple sets of kw v3s but I dont think those are really worth the money. They seem to be the only ones doing twin tube design still which is inferior to monotube. The fortune auto 510 looks really good too for 2k so it would probability be between that and ohlins for my kinda budget at least
Gvazquez
North Carolina
I heard that the pss10s cant handle camber plates or something like that without breaking the strut shaft? I dont feel too good about that. Jrz looks legit also but I'm wondering if I can get similar results with less money. If anyone has researched the vwr tracksport coilovers I'd like an opinion on those too cause it seems as if they modeled their coils after ast and for 2800 bucks they offer a lot. Just throwing out ideas
victorofhavoc
Kansas City
The spec coilover for spec boxsters is still the PSS9 I believe. Take that for what it's worth...
I have the PSS10 currently, but haven't had a chance to get them on track yet this year. I almost went with the Ohlins, but my takeaway from local racers was that for twice the price, you don't quite get twice the coil. They're a bit better for sure, but not 1400$ better. FWIW on full soft, the Pss10 are stiff on the street, but don't punish you like the MSS springs and 034 springs (I wanted to keep DCC like a fool at one time). On full hard I drove over a train track and felt as if someone ripped a disc out of my spine.
It also comes down to how well you know how to setup your car. While most people can mess with a single adjustable to tune rotation just fine, stepping up to a 2 way starts to get more complicated and a 3 way is outside the scope of the majority of people who track their cars. Let's not talk about 4,5-way setups, bump stop tuning, etc. I would say start with what kind of tire you'd like to run, and build around that. If you plan to go to a slick ever, you need at least -3.0 camber front, and preferably -3.5-4.5. If you're running a slick, you'll also want to be running springs in the 650#+ range. That kind of setup on a 200TW street tire will just tear up the tire.
AST, Moton, MCS, Ohlins, Bilstein were my considerations. AST/Moton wouldn't give me any data or information on their dampeners, except for "Our dampers are really powerful so you can run soft springs". MCS I could only get from ground control it seems and ground control's level of communications was so poor (we're talking weeks of lag and following up to get responses), and considering how often those need rebuilt I decided that kind of service wasn't worth it. My friend waited for 12 weeks for a rebuild on a single MCS strut for his M3... Ohlins communication, detail, and quality all seem top notch and I would have pulled the trigger on them, except I had quite a few other things that happened all at once (popped a rim, changing jobs, new baby, blah blah blah life) and I just couldn't justify 2800$ vs 1300$ when I also needed a new fire suit and a couple rims :).
There's nowhere that rebuilds them?
Mini7
Charlotte, NC
I suspect that VWR coilovers are relabeled/rebadged AST 5100 coilovers. They look just like my ASTs on my Mini.
It wasn't a rebuild candidate. The swaybar endlink bracket snapped off. It was the second occurrence. It had been rewelded once, but it was determined that it couldn't be welded a second time.
Just bad luck or do you use a crazy still sway bar or something?
jmason
Frederick, MD
How should I put this diplomatically? I f&@$d up the installation because I’m an idiot? I used a spacer that came with the Superpro end links. I should not have used it. As a result, I installed the end link incorrectly, producing a torque on the bracket. It ultimately failed. I will say the failed weld didn’t look that good. No penetration into the strut tube.
SouthFL_Mk7.5
South Florida
Ride
2019 GTI S
Interesting.
The shop that performed the Superpro LCA, Strut Mount and FSB end link install on my car made the decision not to use that spacer- they gave it back to me when I picked up the car and said “we tried the install with this part but there’s a conflict there we’re not comfortable with!”
I was a little concerned because the instruction sheet clearly diagrams the install with the spacer, but it’s been 6 months now and a couple track days just fine without that spacer.
jmason
Frederick, MD
As I was waiting for my replacement suspension, I learned that the spacer shouldn't be used on lowered cars. Huh? I can't figure out what the spacer was supposed to accomplish.
When I installed my replacement coilovers, I did not use the spacer. Seems to be just fine without it, which is supported by your experience. Good to hear.
