odessa.filez
- Roswell, GA
- 2016 GSW 1.8tsi auto
see signature. running re71rDamn dude how did you get -4.75 camber up front?? Are you on slicks?
I actually run 1/8 toe out (total) front and rear and tire wear is fine. If you see my other post I have been tracking tire wear for some time. I have almost 15,000 miles on my street tires with these settings, and the tire wear has been excellent IMO. These tires do have a little bit of track use as well but mostly street with a lot of highway miles. I drive pretty hard even on the street (when I can) and it is looking like will get about 20-25 thousand miles out of these tires, which all things considered is pretty good IMO. There is a bit more wear on the inside, but if you do any tracking you are going to scrub the outside , so it actually tends to even out the wear.Total toe of 1/16, I’m not concerned with the rear. I do have some concern up front With toe out. 1/16 total toe is not much but the front does so much more work than the rear.
My plan is to adjust back to zero for the street as a precaution. I have toe plates and turn plates. Just need to figure out how many turns of the tie rod to undo the toe. Then I can knock it out quick and easy on rhino ramps.
Jacking the car up to get access is what slows you down and makes toe adjustments a PITA, unless you know beforehand what adjustment is required.
Looks like i will get about the same mileage out of these tires, and that is with a 1/8th toe out front and back from day one. You are right though, toe is what eats tires, but if kept within around 1/8th in or out I find the difference in tire wear is negligible. I had originally set to a 1/4 on the previous tires and witnessed the tires wear down incredibly fast, that is why I reduced it and started monitoring tire wear with this new set. Apparently it is like everything else in life, to much of anything can be a problem, but in moderation...Hah! Looks like I will have to add tire rotation and tread wear measurements to my maintenance logs. Lol
Appreciate you sharing. Not really concerned about camber wearing tires. From past experience bad toe settings can chew up tires pretty quickly.
I generally get about 18-20k out of a set of MPS4S
Which bushings did you replace in the rear? What is the spring rate on your KWs?
I’m planning on going with some toe out up front to improve initial turn in bite. Most probably going on a 1/16 toe out up front and 1/16 toe in the rear for the track.
Here are my values for reference, I do my own alignments so this is not my final (but close) I occasionally take it to a local shop for reference. For $30 they will throw it on the rack and give me a print out.
View attachment 185229View attachment 185230
My alignment and the shop rack usually match very close, but I have learned to trust my alignment over the machine. This is my current toe setting:
I was able to get -2.2 in the rear before I went to spherical bearing camber arms. Im not too sure of the question but it can be done with the stock eccentrics.I like your setup.
I have regular toe plates and turn plates but I have to jack up the car to get to the tie rods. The turn plates aren’t adding any value other than when I measure caster.
Now if I get wheel stands similar to yours but can fit the turn plates, that would be great.
So here’s a question for you seeing that you do your own alignments.
I’m currently at -2 degrees. Curious whether I can max out the length of the rear lower control and then stand up the wheel with the upper camber link to gain some wiggle room to the fuel filler tube and still get the -2 degrees...?
- How much adjustment is in the eccentric bolt for the rear upper camber link? Distance and Camber Adjustment
- How much adjustment is in the eccentric bolt for the lower rear control arm – inner pick-up? Distance and Camber Adjustment
- I’m assuming that it is the same for both, as the eccentric bolt is the same part# if I am not mistaken.
I was going to see if an alignment tech was on the forum, who could provide the info.
Another question is, what is the toe change per one turn of the tie rod in inches/mm/degrees?
I like your setup.
Good to know there is -3.5 in stock adjustments with the upper and lower eccentric bolts.
What is your ride height. Fender to ground?
I can see how the eccentric bolts are a PITA using strings. On a digital alignment rack you can hold the the bolt in position while you lock down the nut and invariably you have to learn to hold it over or under the desired setting as you tighten the nut to pull it to the spec you want. With strings its trial and error to get it exact. With and adjustable camber arm you can science it out based on the thread pitch.
With front toe I believe it’s a M14x1.5, so every turn is 1.5mm multiplied by the torque arm on the spindle the tie rod is bolted too. Then it’s easy to make adjustments for the track and then undo them for the street. If 1/8” toe out is not causing additional tire wear I might not mess with it.
I still want to know how much to adjust each side to get 1/8” total toe.
Looks so buttoned down. Nice shot!
