Diggs24
- de plains! de plains!
- 2015 GTI
Ok, so taking a pump gas IS38 that makes peak 360whp@5500 and then tapers down towards redline this turbo can make 360whp all the way to redline? So, no further peak power just more power under the curve?it doesn't need dynos, it uses oem spec wheels so it will make the same power as an oem is38. Where it makes "more" power is the ability to hold boost all the way to redline and not have to taper. So you can run whatever boost level an is38 can run before it becomes a hair dryer.
