Diggs24
- de plains! de plains!
- 2015 GTI
Can you log it with eurodyne tool instead?
Lol. I get it for $78 /5 gal. Just wanted a 1/4 tune for the strip until I decide what path I want to go with this car from here.
Yeah. My 93 tune is 28psi, and I run 26 on the 105. Despite a drop in boost the power gain is pretty decent with the added timing.
I’ve never dynod. Never really plan to, just focused on 1/4 times. I’d say it probably makes mid 4’s though.
So it is safe to set it at 28 psi on stock fuel? but the ecu will just pull timing and protect it from being unsafe? or is it better to keep it on lower psi and avoid it pulling timing to begin with?
No. Leave it alone for now. He has an IHX475 not a 600. Graba couple logs with the powertap when you get it. Follow above and log everything. Post to datazap.
The reason I say that is I can already see you running out of fuel. No fuel=lean=bad news for motor. Just be patient.
Planning to see how I do against apparently the "fastest IS38" GTI in houston tonight. As well as an e85 tuned one iirc.
I wouldn't race it either. Be patient.
Well?
