- Phoenix
- 2018 SE DSG
Gotcha. Makes sense then because that FCP warranty is fantastic.Nope.
I never recommend the XL unless there’s plans in place for MPI/LPFP/PM4.
The standard Vortex is the HPFP weapon of choice, but I’d love to compare your XL/HPFP logs to one to see just how much differently they spool. I’m guessing it’s not all that drastic
Happy to share, DM me your email address.
I never hear many recommend the Vortex XL on pump. I have a lot of head room with this turbo if I want to push it further. Autotech HPFP on 93 tuned by ED and she pulls well. I have disappointed many drivers of "faster cars".
My understanding is that it's not that XL on pump sucks, it's just you're leaving so much on the table. Having the head room for later is nice for some, but the recommendation is typically stick with standard housing vortex if you are only going to run 93 with HPFP.I never recommend the XL unless there’s plans in place for MPI/LPFP/PM4.
SameI'd be interested in seeing the comparison if it gets done.
Yup...I’d run the XL just for the cooler EGT’s regardless of fueling.
Happy to help, I have logs of vortex HPFP only and HPFP + LPFP on 93 and E30 available. Multiple tuners as well. Would be interesting to see differences, if any.I don’t have standard Vortex logs to compare it to
Nah, Ed only recommended a HPFP when he tuned me on the XL. Never made mention of needing a LPFP during tuning.Yup...
It’s not like you are getting the full Potential of either version when on pump gas anyways, so the theory of leaving in on the table holds true for both standard and xl, but on the same fueling youll still make more power on the xl, I just don’t know if with the xl you’ll need a lpfp also for the upper rpm range.
What is safe boost level for the IS38? I just installed one on the TT. Right now at 25, no bolt on.If you can't get ethanol, get a vortex with a cobb tune. Stock IS38s are known to blow up on stage 2 levels of boost. The vortex spool is amazing and they've addressed the reliability shortcomings of the is38.
Cobb is fine, and you can recoup most if not all of the AP cost when you resell it. I would try to get a 450 + PM4 or RS3 LPFP and MPI if you can swing it, but HPFP internals and a 450 on stock controller is doable for pump gas. I had a poor experience with an upgraded HPFP and wish I'd done MPI in the first place, but I'm running e85 so ymmv.
edit: saw your current tune. Definitely at least get a stratified or EQT ots map if you want a bump, but if you're going to spend the time/effort on a turbo swap, do it right imo.
My local shop said to keep it under 29 as far as shredding them, plus you want to keep resolutions on your pressure sensor above your limit to monitor for overboost correctly. 25 sounds pretty safe to me.What is safe boost level for the IS38? I just installed one on the TT. Right now at 25, no bolt on.
IC coming, no DP.You installed an IS38 without bolt ons? So no DP or IC? Just running a stage one IS38 map? Might be a bit much for an IS20 stock IC as that is smaller than the Golf R, S3 IC.
Probably want to limit that level to low-mid airflow and account for the couple psi that is dropped along the way to the engine.My local shop said to keep it under 29 as far as shredding them, plus you want to keep resolutions on your pressure sensor above your limit to monitor for overboost correctly. 25 sounds pretty safe to me.
