Diggs24
- de plains! de plains!
- 2015 GTI
Pull the filter off.
Ohhh I think I finally get what you are saying. Like the test is basically just saying only 20 percent in here is gas the rest could be god knows what. It's not a given that it is actually good ethanol? Is that what you're getting at?If by test kit you mean vial and water? That's still the same, the gas is up top and the everything else is at the bottom. It likely is E80 but the test is not scientific enough to conclude that.
What do you mean pull the filter off?Pull the filter off.
Correct. Which is why I don't think it's likely a gas quality issue.Ohhh I think I finally get what you are saying. Like the test is basically just saying only 20 percent in here is gas the rest could be god knows what. It's not a given that it is actually good ethanol? Is that what you're getting at?
However wouldn't a gas issue show up in multiple cylinders being retarded?
Pull the sock off the lpfp. Very risky though.What do you mean pull the filter off?
How does the difference in compression between GTI/R effect timingOh lord theres people running 19* and 33psi on stock motor on my set up. My friend with audi, same set up, is running 15* and 32psi on kill mode. Zero knock. He dailies at 10* and 28psi
Same tuner, same set up
I thought you just put in a new pump.Holy crap!
https://datazap.me/u/samuphil/fueling-test?log=0&data=1-13&mark=27
Yep I think pump is taking a shit. This is on the brand new controller too btw.
Holy crap!
