Tires for GTI MK7
plastermaster
Gualala
As I recall, there were/are only 2 summer tires worth buying. Don't cheap out, you're betting your life and the lives of everyone in your car! I looked at Conti's ECS and Michelin PS4S. The PS4S seemed to be better on paper so I bought those. They stick like glue as long as you don't exceed the laws of physics.
As for tread wear, newbies need to realize that all ultra high performance tires are made with a soft rubber. And soft rubber wears much faster than hard rubber. If you bought hipo tires you bought them for performance, so don't expect to get more than 12K miles or so from them if you drive in city, where you're constantly stopping and starting. The fronts wear faster on a FWD car, and still wear faster with AWD. And I don't know about you, but I go with the study I read where once you get down to 4/32" depth your performance drops considerably, especially on wet roads. They only have about 9-1/2 32nds to start, so take that into consideration. You want long treadwear, go look what Gramps is rocking on his SUV.
I'm in the market for tires too and I hope my question might be helpful to the OP as well as myself. I know ultra high performance tires do not wear as well, and might not be as quiet or as smooth riding as a lower performance tire. My question is, if I am not needing extreme grip to keep me from sliding off the road, BUT still want the subjective feel of my ride to feel precise, sharp, with immediate steering response, you know, that riding on rails metaphor,,,,will that be best achieved with ultra high performance tires? My only experience with ultra high performance tires was back in the day with Potenza RE950's loved the way those tires handled but perhaps I could have gotten the the same out of a lower performance tire. They also lasted many miles for me. Too bad they don't make them anymore, and the 970s and 980s don't get the all that great of reviews.
Sumfuncomet
I’ve had Indy 500 on three cars 2017 Alltrack, 2018 GTI and 2012 Mini, you might say I love these tires. Living in Maine we use dedicated setup wheels and tires for winter or summer. We do NOT use all season tires. Mostly Nokians, Michelin Xice, Sumitomo ice edge or Altimax. I prefer studded tires. Don’t buy all seasons for Florida!!!
YamR1rider
Tampa, FL
Yes, that is exactly what they are designed for. And will be plenty grippy if used within their specified temperature parameters. Like for like summer UHPs will outperform all season UHPs in all conditions unless its cold out.
dosjockey
South
You'll want to look at solid carcass construction and a single layer tread compound, as well as a decent amount of bead filler and fully wrapped plies with high turn up; and tread sections with solid bolstering plies. You want something manufactured on fully segmented molds, and a tread compound appropriate for your environment.
Ignore reviews, and look at how they're manufactured. That will tell you everything you need to know.
The General Grabbers on my Rover are more precise than many passenger car and even performance tires, simply because they're built properly.
Here's an example of the data you want to be looking at:
Look at how the plies wrap under the bead wire and all the way up past the shoulders under the tread section. Instead of filler, they're using an insert to bolster the above bead area. You'll see two little black things on either side of the bottom belt; those are tread section stabilizers, and they've used a number of cap plies to bond everything together up there for rigidity.
This is a tire that won't see a lot of lateral deflection, which in turn will increase steering response. I'm not saying other options aren't out there, this is just the first thing that came to mind, as I know they make the cutaways available easily enough for me to just find one to post.
You want to be looking at this stuff. Everything else can be ignored. Period. All that matters is how the tire is constructed, and whether or not they can keep to their own production standards. Doesn't matter who makes it, who likes it, what's it's fitted to from the factory... That's all irrelevant marketing nonsense and reviews by people who haven't used enough tires to know better.
Find out how they are built, and you will buy the tires you want.
dosjockey
South
@ dosjockey, Great post! I will look further along the lines you suggest.
The biggest thing to remember beyond that is that tires are part of your suspension system, and given most haven't used too many different vehicles or set up one vehicle in enough ways, this is where asking opinions comes in handy. On this vehicle, for example, you might find more stability with a little less rigidity, or a little more. It depends on how it's set up; but you're after a very specific adjustment; not some mythical "best" tire.
Unfortunately, I can't give an actual opinion on what to buy for a Mk 7.5 GTI, as I've only had one for a little over three weeks. I have a hypothesis in regard to what it needs, but until it's a theory, it's useless for advice.
You know what you want in a tire; the feel of improved steering precision, so you're closer than most tire buyers ever get to buying the right product for their use case. In order to produce that feel, you'll want to look at points where tires deflect; and the two most common places are the tread section and the bead filler area. This is where manufacturers sacrifice precision for comfort, but that doesn't mean you have to give up comfort if you know what you want.
Understanding how all that data goes together will help you avoid purchase mistakes, and land you with something you like. Try to imagine the forces acting on that tire in your head before and after driving around a bit, and you'll sneak closer to being able to determine which aspect of the carcass or tread is letting you down. :)
The Fed
Old Guys Rule
Florida
It will start to come down to how much you care to spend. IIRC, I paid a little less than $300 per tire, mounted and balanced, with a 2-year RH warranty. On a smooth road and in Comfort mode, they're very quiet.
So much goes into that decision.
Top choices for inexpensive good tires are...
Indy 500 - great feel and dry traction, not fantastic in the rain. A little noisier than the other two. Have them on my son's GTI. Get this if you're looking for the sportiest feel.
FK510- fantastic in the rain, great dry traction, a little soft in the sidewall. I purposely bought them to soften the ride after adding stiffer springs. Run a couple extra psi in the tire and get this if you're looking for a softer commute. Since I have separate wheels and tires for track and a stiffer suspension, it was my choice for those reasons.
G Max RS - side wall somewhere between the other two, great dry and wet traction. This is the best compromise between the other two.
dequardo
Waukesha, WI
Agree on these. I’ve made my preference known before and don’t wish to repeat it here as the price/performance ratio is off the charts. Oh and they only weigh 20 pounds each. :cool:
Ride
I don't want to read the whole thread to find that post so what tire are you talking about?
dosjockey
South
The Indy 500 has extremely bolstered shoulder tread blocks at the expense of all weather stability. It's going to hook in the dry one way or another, but feel is going to come down to reinforcement.
They're about one step above cheater slicks.
FK510 and the GMax units are more appropriate for everyday street use, and the GMax has an unbroken circumferential ridge for general stability, noise, and higher speed, yet lower G turns.
That General isn't competition for the Indy 500, though. You'll have to move to their sister brand for a proper comparison: Continental; and specifically, the ExtremeContact Sport.
SouthFL_Mk7.5
South Florida
Ride
2019 GTI S
I live in Miami. Currently using a set of Indy 500 on my wife’s car and P Zero on the GTI. Really happy with both tires.
The Firestone are a great value. Nice performance for a budget tire. Good turn in and steering response and grip. A little numb on center.
The P Zero can turn some laps at the track rather well and ride rather quietly and comfortable without compromising feedback.
plastermaster
Gualala
I was lamenting the lack of comparison (test results) between tires of different categories in an earlier post. Such comparisons would quantify for consumers the trade offs in choosing their category of tire. I found on Tire Rack's testing that for grand touring AS and UHP AS tires, they use the same cars. As expected the UHP tires of course have better stats for stopping, cornering, and track times, but interestingly not much. 100ths of a second wins races, and a few feet in stopping distances can save lives, but for day to day fun driving not quite at the tire's limits, the results seem to indicate the differences to be close. Close is a relative term, so close for one driver might be not so close for another. I might add that on the tests that I compared, the UHP tires were also a little fatter. 245 vs 225. That alone would account for some extra stickiness on the road. Tire racks test results present data in the form of scores, and also actual times and distances. On the scoring there is some overlap between the 2 categories, but not for the same brand of tire. In case anyone is interested the 2 tests are here and here. But, all said, its hard to say how much the data comparison translates to subjective experience behind the wheel.
7thVW
Florida
The beauty of the vehicle, it is reasonably priced and functional. If you upgrade from stock tires, no need to go wider. The vehicle can probably do more than you can.
Track vehicles with use Michelins b/c they they get to put the name on the wall. Think I run Bridgestones on the VW and I can never get up to speed. Keep in mind a softer tire will wear more quickly. A lot of that people that cant decide like the Michelin A/S 3. Probably lasts longer than a condom. If you want quick response, the Sport Cup is going to be tough to beat.
I have run Goodyear RSAs on vehicles, and they work fine. What is the average temperature and rainfall where you are located?
ack_attack
IL - Illinois
From my experience, I would go with the DWS06 over the Pilot Spot A/S 3+. To my surprise, the Pilot is quite bad in colder wet temps, they turn into hard plastic and don't grip, pretty horrible even in light snow.
+1
I had both on a mk6 TDI.
IMHO, A/S 3+ have slightly better dry performance, but the DWS06 weren’t that far behind. Overall grip is almost the same, but the DWS06 takes a little longer to take a “set” (probably because of a softer sidewall). But at anything but “oh shit!” speeds, I doubt many people would complain.
DWS06 were pretty amazing in the wet, with A/S3+ not far behind. In fact, DWS06 are my favorite tires for driving in the rain.
In wet, slushy snow, the DWS06 were very good; A/S 3+ started to get a little iffy. In drier snow, usually meaning colder temps, the DWS06 were ok up to about 3” of snow, then they got to be a little slippery, whereas the A/S 3+ were really slippery. Of course, neither will be as good as dedicated snow tires.
DWS06 have the advantage in comfort all through the tread depth. DWS06 were quieter, too. They got louder as the tread depth got to the point of replacement, but still quieter than the A/S 3+.
When it came time for new tires on my mk7.5 GTI, I went with DWS06. They aren’t the best at anything, but do A LOT of things very well (much like a GTI).
Both are very good choices, performance-wise, for a HIPO all-season tire. A/S 3+ have the edge in performance overall. DWS06 a smidge behind in performance (but not by much) and have the edge in comfort and snowier conditions. Pick your priority, and you have your winner.
Just my $0.02 - YMMV
MSchott
Michigan
I had the DWS06 on my 2014 RWD BMW 328 and while they did a lot of things well, the soft sidewalls made for mushy steering feel. I have the A/S 3+ on my GTI and the grip and steering feel is exceptional. They are fine in the snow for a high performance AS but light fluffy snow is an issue. To me, the benefits outweigh that issue.
Ital
Italian in CT
Depends what you are looking for. From my experience
Michelin best performance but loud
Pirelli are the most quiet
Continentals are somewhat in the middle and cheaper
I went with the pirelli because I do a lot of highway driving since mine is a daily driver
