Stop!
Let's not get too ahead of ourselves, an extra 100-200hp requires a little more responsibility. Luckily for you, Revo offers two big braking kits for the MQB Golf R.
Available in both a 355mm and 380mm disc, with Red or Black 6 piston calipers by Alcon, these kits are suited perfectly for the spirited driver who needs more from their car.
Revo Big Brake Kit Upgrade
Improves stopping power under any condition
OVERVIEW
The Revo Big Brake Kit Upgrade is engineered to improve your stopping power in any condition. Whilst stock brakes are perfectly adequate for general driving; the braking system is often overlooked when enhancing a vehicle's performance. The Revo brake kit is made by world-leading brake manufacturer Alcon; utilizing over 30years of motorsport braking innovation only the best materials, techniques and processes have been used.
In-depth testing is a key factor in the development of our products; our brake kits have been aggressively tested in a variety of conditions in both road and track scenarios to ensure they meet the constant high stress of track days, sprints and fast road driving. Test kits were installed on our in-house development vehicles along with several vehicles around the world and put through their paces to prove their worth over the stock setup; providing exceptional performance combined with consistency and durability you can rely on, corner after corner, stop after stop.
Made by world leading brake manufacturer Alcon, only the best materials, techniques and processes have been used, with every step of the manufacturing process completed in the UK. Alcon has been at the forefront of motorsport braking innovation for over 30 years.
BENEFITS
- Low Rotational Mass
- Improved Pedal Responsiveness
- Lower Long-term Maintenance Costs
- Superior Heat Dissipation: Less Prone To Fade
- Increased Braking Performance On & Off Track
100 - 0 MPH AVERAGE STOPPING DISTANCE
CALIPERS
Revo lightweight six-pot caliper is a single-piece aluminium Mono-bloc design. This design has been used to maximize rigidity, pedal feel and overall braking performance. The caliper incorporates a progressive six-piston setup to give great brake balance, and high quality seals increasing resilience to road salts and other corrosive elements.
DISCS
We use a two-piece floating disc and hat design to efficiently dissipate heat. The friction surface features crescent groves designed to increase bite and remove debris from the pad surface giving the perfect balance between brake feel and longevity. The discs feature internal cooling vanes that draw air from the center of the disc outward to maximize heat dissipation and minimize heat transfer to the calipers, pads, and brake fluid, which plays an all-important part in providing consistent stopping power for your vehicle.
BRAKE PADS
We supply Revo brake kit with Ferodo DS Performance Pads that offer a consistent pedal feel and fantastic braking performance both from cold and when hot. Combined with low wheel dusting, minimal noise characteristics, and low disc and pad wear rates this is the ideal pad compound for general road and track driving.
BRAKE LINES
Revo brake kit is supplied with stainless lines; consisting of a PTFE inner and stainless steel braided outer to eliminate the spongy feel of original rubber hoses, provide superior resistance to corrosion, and offer consistent braking performance.
BRAKE FLUID
Revo brakes are supplied with Motul Dot 5.1 brake fluid; specifically designed for brakes systems with ABS. This is a long-life synthetic brake fluid with superior boiling point qualities to conventional Dot 3 and 4 spec. fluids.
KIT CONTENTS
- Revo by Alcon Caliper x2 (3.3 Kg Each)
- Revo by Alcon Discs x2 (7.66 Kg Each)
- 6061 Aluminium Anodised Bell x2
- 6061 Aluminium Anodised Caliper Bracket
- Revo Stainless Steel Braided Brake Lines
- Motul Dot 5.1 Brake Fluid
- Ferodo DS Performance Brake Pads
Wheels
While the Revo brakes can fit behind stock 19" Golf R wheels with the use of a spacer, or most aftermarket wheels, Revo decided to go above and beyond.
Revo RV018 and RV019 Wheel
Developed not only for aesthetics but with performance and function at the forefront of its design.
OVERVIEW
The 18" and 19” cast alloys are lightweight yet exceptionally strong wheels, designed in-house at Revo HQ and manufactured by OE Manufacturer and Motorsport specialist Rimstock making it a truly British product. Utilising the low-pressure casting process used in the production of Rimstock’s tried-and-tested motorsport wheels, we were able to produce a timeless motorsport classic that could perform where it matters most; on the road.
As with all Revo products, the performance was a key factor in our design requirements. With an impressive weight of 21lbs for the 18x8 and 22lbs for the 19x8.5, Revo wheels offer a huge reduction in unsprung mass over a factory wheel. The 10 spoke design not only looks great but is designed to clear your Revo big brake kit and offer more efficient cooling to the brake system than other wheel designs. On top of the performance and aesthetic qualities, Revo wheels also come with full TÜV approval.
With a classic motorsport look featuring an embossed Revo logo and branded center cap to compliment the subtle styling, the wheel is available in a choice of color finishes.
BENEFITS
- TÜV approved
- Lightweight at only 21-22lbs
- Made in the UK
- 2-year manufacturer warranty
- Fits Revo big brake kit
COLOR OPTIONS
- High Gloss Black
- High Gloss Silver (19" only)
- Matte Anthracite
- Gloss Anthracite (19" only)
- Matte Bronze
