The Revo Mk7 Golf R Mega Thread
Pacific German
GOLFMK7 Official Sponsor
United States
Hey Golf Mk7 forums!
We decided to make a Mk7 Golf R Revo Mega Thread to keep you updated on all of their cool stuff! In this thread we will be compiling data and information regarding Revo's software tunes, Performance Packages, IS38ETR Turbo Kit, wheels, brakes, and so much more.
Power!
Lets get started with the fun stuff! Revo has a full suite of tuning software for both engine and DSG transmission (currently 6 speed gearbox only) available to the market right now for your 2015+ car. Software ranges from Stage 1 to Stage 3+ including fully switchable software for those who plan to run 91 octane, 93, 100, ethanol blends, stock boost, valet mode, etc.
PERFORMANCE ECU SOFTWARE
Revo performance Software is designed to safely enhance the driveability of your vehicle, giving access to more power and torque throughout the rev range while maintaining the extensive factory safety mechanisms. Revo Software offers a perfect balance of performance, economy, longevity, and safety so you can drive harder, for longer.
OBDII Port Installed
OBDII Port
Installed
Vehicle Health Check
Vehicle Health
Check
Authorised Dealerc Set-up
Authorised Dealer
Set-up
TCU SOFTWARE
Revo Transmission Control Unit Software allows your automatic gearbox to work in harmony with Revo ECU Software. As well as enhanced driveability and quick shifts, Revo TCU Software is packed full of features. 3
Shift Points
Optimised
Shift Points
Launch Control
Dynamic
Launch Control
Global Development
Global
Development Programme
Read More
Click here to view the Revo Golf R Stage 1 Product Page
Typical Stage 1 cars will see +50hp and tq over stock dependent on fuel and the dyno used. Gains are immediately noticeable and stronger through the entire power band. No hardware changes are required for stage 1, and the software will adapt well to an intake, intercooler, charge pipe, or cat-back exhaust upgrade.
SPEED LIMIT UNLOCK
The top speed limit for this vehicle has been removed.
TEMPERATURE PROTECTION
Enhanced engine cooling and oil temperature management.
COLD START PROTECTION
Boost is limited until safe oil temperature is reached.
SERIAL PORT SWITCH (SPS)
Switchable software for Stock, 2 performance modes and Antitheft.
All Revo software must be flashed at an Authorized Dealer! There are over 400 dealers World Wide, so this should be pretty easy for you to find your local dealer and book an appointment.
Click Here to view the Revo Dealer Locator Page.
If you are located in Southern California, all Revo software and hardware is in stock at our state of the art 7,200 sq ft. facility. Please feel free to give us a call or drop an email to learn more!
949.215.7717
info@PacificGerman.com
Pacific German
United States
Revo also has a full Performance Package for the Golf R. This pack consists of a Carbon Series Intake system, Intercooler, Intercooler Piping, and matching stage 2 software. The only additional requirement for the Stage 2 Performance Package is a downpipe.
Click Here to view the Revo Performance Pack Page
Click here to view the Revo Stage 2 Software Page
Typical gains of a Performance pack car is 100hp and 125 lb ft over stock, yielding a total of 400hp! This is of course dependent on fuel, these numbers have been achieved using a US equivalent 93 octane fuel. 91 will see slightly lower numbers. Most cars can run a 91 octane / ethanol blend, or 93 octane / ethanol blend and run higher Performance maps as long as their Revo dealer approves the setup via data logging and ensuring the vehicle is equipped with the correct hardware. Some cars will see higher than 400hp!
EVERYTHING YOU NEED
FOR THE POWER YOU CRAVE
Enhanced power delivery, unique safety features and exhilarating response at your disposal, the Revo Performance Pack delivers much more than peak power figures. Whatever drives you, the Revo Performance Pack has it all. Engineered to perform, only Revo offers a complete tuning solution specifically designed for your vehicle.
Air Intake Icon
AIR INTAKE SYSTEM
Performance ECU / TCU Software
PERFORMANCE
SOFTWARE
Intercooler Pipe Upgrade Kit
INTERCOOLER PIPE UPGRADE KIT
Intercooler
INTERCOOLER
Hardware!
Lets take a look at the hardware break down from the Performance Pack. Each part is available separately, but the best bang for your buck is buying the complete kit.
CARBON SERIES
AIR INTAKE SYSTEM
Beautifully crafted from the highest quality 3k carbon, the Revo Carbon Series is much more than a visual enhancement. Designed to directly replace restrictive OEM components, the Carbon Series has performance woven into the core of every product.
Increased Diameter
Increased
Diameter
Direct Internals
Direct
Internals
Authorised Dealer Icon
Thermal
Barrier
Learn more about this product
The Revo Intercooler Pipe Upgrade kit reduces charge system resistance and improves flow over the restrictive stock pipework. Featuring fewer restrictions for smoother airflow, and optimized routing, the turbo meets less resistance and can perform more effectively.
Direct Replacement
Direct
Replacement
Increased Diameter
Increased
Diameter
Increased Diameter
Direct
Internals
INTERCOOLER UPGRADE
The Revo Intercooler was built around a simple principle; create a cooler that can keep up with your demand for power. Unique design features lower intake air temperatures, minimise pressure drop and allow the engine to produce impressive power and torque with Revo Software, ensuring you get consistent performance when you need it most.
Designed to Work in Harmony
Direct
Replacement
Unique Fin Design
Unique
Fin Design
Minimised Pressure Drop
Minimised
Pressure Drop
Pacific German
United States
Stop!
Let's not get too ahead of ourselves, an extra 100-200hp requires a little more responsibility. Luckily for you, Revo offers two big braking kits for the MQB Golf R.
Available in both a 355mm and 380mm disc, with Red or Black 6 piston calipers by Alcon, these kits are suited perfectly for the spirited driver who needs more from their car.
Revo Big Brake Kit Upgrade
Improves stopping power under any condition
OVERVIEW
The Revo Big Brake Kit Upgrade is engineered to improve your stopping power in any condition. Whilst stock brakes are perfectly adequate for general driving; the braking system is often overlooked when enhancing a vehicle's performance. The Revo brake kit is made by world-leading brake manufacturer Alcon; utilizing over 30years of motorsport braking innovation only the best materials, techniques and processes have been used.
In-depth testing is a key factor in the development of our products; our brake kits have been aggressively tested in a variety of conditions in both road and track scenarios to ensure they meet the constant high stress of track days, sprints and fast road driving. Test kits were installed on our in-house development vehicles along with several vehicles around the world and put through their paces to prove their worth over the stock setup; providing exceptional performance combined with consistency and durability you can rely on, corner after corner, stop after stop.
Made by world leading brake manufacturer Alcon, only the best materials, techniques and processes have been used, with every step of the manufacturing process completed in the UK. Alcon has been at the forefront of motorsport braking innovation for over 30 years.
BENEFITS
  • Low Rotational Mass
  • Improved Pedal Responsiveness
  • Lower Long-term Maintenance Costs
  • Superior Heat Dissipation: Less Prone To Fade
  • Increased Braking Performance On & Off Track
100 - 0 MPH AVERAGE STOPPING DISTANCE
CALIPERS
Revo lightweight six-pot caliper is a single-piece aluminium Mono-bloc design. This design has been used to maximize rigidity, pedal feel and overall braking performance. The caliper incorporates a progressive six-piston setup to give great brake balance, and high quality seals increasing resilience to road salts and other corrosive elements.
DISCS
We use a two-piece floating disc and hat design to efficiently dissipate heat. The friction surface features crescent groves designed to increase bite and remove debris from the pad surface giving the perfect balance between brake feel and longevity. The discs feature internal cooling vanes that draw air from the center of the disc outward to maximize heat dissipation and minimize heat transfer to the calipers, pads, and brake fluid, which plays an all-important part in providing consistent stopping power for your vehicle.
BRAKE PADS
We supply Revo brake kit with Ferodo DS Performance Pads that offer a consistent pedal feel and fantastic braking performance both from cold and when hot. Combined with low wheel dusting, minimal noise characteristics, and low disc and pad wear rates this is the ideal pad compound for general road and track driving.
BRAKE LINES
Revo brake kit is supplied with stainless lines; consisting of a PTFE inner and stainless steel braided outer to eliminate the spongy feel of original rubber hoses, provide superior resistance to corrosion, and offer consistent braking performance.
BRAKE FLUID
Revo brakes are supplied with Motul Dot 5.1 brake fluid; specifically designed for brakes systems with ABS. This is a long-life synthetic brake fluid with superior boiling point qualities to conventional Dot 3 and 4 spec. fluids.
KIT CONTENTS
  • Revo by Alcon Caliper x2 (3.3 Kg Each)
  • Revo by Alcon Discs x2 (7.66 Kg Each)
  • 6061 Aluminium Anodised Bell x2
  • 6061 Aluminium Anodised Caliper Bracket
  • Revo Stainless Steel Braided Brake Lines
  • Motul Dot 5.1 Brake Fluid
  • Ferodo DS Performance Brake Pads
Wheels
While the Revo brakes can fit behind stock 19" Golf R wheels with the use of a spacer, or most aftermarket wheels, Revo decided to go above and beyond.
Revo RV018 and RV019 Wheel
Developed not only for aesthetics but with performance and function at the forefront of its design.
OVERVIEW
The 18" and 19” cast alloys are lightweight yet exceptionally strong wheels, designed in-house at Revo HQ and manufactured by OE Manufacturer and Motorsport specialist Rimstock making it a truly British product. Utilising the low-pressure casting process used in the production of Rimstock’s tried-and-tested motorsport wheels, we were able to produce a timeless motorsport classic that could perform where it matters most; on the road.
As with all Revo products, the performance was a key factor in our design requirements. With an impressive weight of 21lbs for the 18x8 and 22lbs for the 19x8.5, Revo wheels offer a huge reduction in unsprung mass over a factory wheel. The 10 spoke design not only looks great but is designed to clear your Revo big brake kit and offer more efficient cooling to the brake system than other wheel designs. On top of the performance and aesthetic qualities, Revo wheels also come with full TÜV approval.
With a classic motorsport look featuring an embossed Revo logo and branded center cap to compliment the subtle styling, the wheel is available in a choice of color finishes.
BENEFITS
  • TÜV approved
  • Lightweight at only 21-22lbs
  • Made in the UK
  • 2-year manufacturer warranty
  • Fits Revo big brake kit
COLOR OPTIONS
  • High Gloss Black
  • High Gloss Silver (19" only)
  • Matte Anthracite
  • Gloss Anthracite (19" only)
  • Matte Bronze
Pacific German
United States
IS38ETR V2 | ENHANCED TURBO UPGRADE
An Enhanced Turbo upgrade from Revo is the next step in performance from the Factory Turbo. Utilizing the existing housing, all internals are replaced for reliability and any restrictive parts are redesigned or upgraded to ensure the performance that Only The Driven demand
REVO IS38ETR V2 TURBO
2.0 TSI EA888 GEN3
The next generation of Revo IS38ETR Enhanced Turbo offers even more exhilarating performance than before. Revo offers a reliable package capable of over 500HP without the need to upgrade engine internals or DSG clutches. Whilst also focusing on the driveability and feel of the vehicle, on-road or the track.
Only Revo Enhanced Turbos are specifically designed to work in harmony with your vehicle and Revo Software. Engineered to directly replace the stock turbo, the Revo IS38ETR is a high-quality upgrade, precision balanced to motorsport tolerances to improve performance and ensure reliability.
KEY FEATURES
  • Capable of 500HP +
  • Custom designed compressor and turbine wheels
  • 360º thrust bearing kit with custom direct oil-fed pads
  • Precision balanced to motorsport specification
  • Designed in harmony with Revo Software
Revo IS38ETR V2 Turbo Upgrade
DIRECT REPLACEMENT
A direct replacement for the IHI Turbo found on 2.0 TSI EA888 GEN3 engines, the IS38ETR is an enhanced version of the OEM IS38, with increased airflow from the re-profiled housing and larger compressor and turbine wheels. Revo Hardware and Software are the key to achieving this performance and have been developed to work in harmony with the ETR upgrade.
TURBO FEATURES
The high-performance Revo IS38ETR offers a significant upgrade over the stock IS38 whilst maintaining the original fitment and compressor and turbine housings. The compressor and turbine housings have been CNC re-profiled to match the custom-designed larger wheels and stronger shaft. Strength is a key factor to the IS38ETR, a replacement back-plate machined from a single billet piece offers greater resistance to warping, while the increased diameter shaft eliminates the weakness in the OE part.
COMPRESSOR WHEEL
The larger compressor wheel has been machined from a solid billet of aluminium giving a much stronger construction. The new custom design gives the highest level of aero performance, providing superior flow characteristics to achieve the required boost levels with less effect. The lightweight construction of the compressor wheel also ensures low inertia, resulting in increased performance.
TURBINE WHEEL
The precisely engineered turbine wheel has been made with a custom high flow aero blade profile to compliment the aero of the compressor wheel. The result is an extremely high flow aero turbine wheel which increases exhaust gas choke flow limits and reduces backpressure.
HOUSING AND BEARINGS
The bearing housing has also been enlarged and upgraded to make room for a specifically designed 360° thrust bearing system, incorporating a custom 4 oil-fed thrust pad for increased reliability. Precision VSR balanced to levels above the OEM specification, something seen in the motorsport industry. This reduces vibration to the lowest possible level and improves the performance and reliability of the turbocharger.
INTEGRATED RECIRCULATING SYSTEM
The integrated recirculation valve is fundamentally a blow-off valve integrated into the compressor housing. When the throttle valve is closed and the pressure in the inlet drops, the valve opens and air from the discharge side of the compressor is diverted back into the inlet of the compressor. This helps to avoid the compressor going into surge.
TURBO MUFFLER DELETE
The Revo Turbo Muffler Delete offers a high-quality single piece replacement for the OEM part which allows for smoother uninterrupted airflow, increasing throttle response and providing improved turbo acoustics. Its single-piece design allows air a more direct path when exiting the turbo, smoothing flow to offer enhanced throttle and boost response.
RESEARCH AND DEVELOPMENT
Utilizing decades of experience in software calibration and precision turbo engineering, Revo is proud to offer a package that provides the performance you demand and the reliability you expect.
The IS38ETR forms one part of this package; with all available Revo hardware and software having been designed and tested to work in harmony to achieve exhilarating performance that only the driven demand; the result of extensive development, testing and prototyping program.
The aim from the outset was to achieve a balance of top-end power and bottom-end response, without having to forge internals. Combining extensive turbocharger manufacture experience with Revo’s industry-leading ECU calibration and hardware design, we have been able to achieve incredible performance results without compromising on component reliability or engine longevity.
DYNO GRAPH
Dyno testing was carried on our inhouse DynaPack chassis dynamometer, which measures performance at the wheel hubs, for comparisons between a Stock VW Golf R with IS38 Turbo and the same vehicle fitted with a full Revo performance Pack and IS38ETR turbo.
  • Stock Golf R Peak performance: 283HP / 379NM (HP at the hubs)
  • IS38 ETR Peak performance:: 457HP / 567NM (HP at the hubs)
  • Peak Gains: +174HP / +188NM
  • Max Gains Over Stock: +183HP @ 6500RPM / +188NM @ 4600RPM
Currently for the IS38ETR Generation 2 Turbo, the only ID supported in the USA is 8V0 906 259H. Please drop me an email or contact your local Revo dealer if you are interested in the turbo kit or if you have a different software ID, so that we can have a file built for your car.
NCM
Fort Wayne, IN, USA
2015 Golf R
Like:
In order to guide my driving enthusiasm, I keep oil temp permanently displayed on the dash, so this seems like a good idea.
Neil
impulsive.ca
Most if not all OTS tunes have those safeguards. With that said, I love revo products. Too bad they're so damn $$.
