mk7_bk
- Philadelphia Area
Tank not 13 gallons? The car will throw a CEL if it cant keep trims and railpressure in check. But yeah dont get on it and the car will have best chance dealing with it in higher rpm and low load.Question for you all. Maybe should start a separate thread, but figured I'd start here.
I was a little distracted with let's just say a stunning view while filling up today and forgot to stop at 2.5 gallons of e85. Accidentally put in 5 gallons. According to my calculations, that's about 52% ethanol content.
I am 1.8, stock pumps with APR IS38 tune. Anything I should worry about, or just don't give it full throttle?
How can I measure using Torque if fueling is insufficient or running lean?
Yeah, tank is 13 gallons, but I already had e85 in there from previous tank. It was 5gal e85, 7 gal 93 and I previously had about 30% in the tankTank not 13 gallons? The car will throw a CEL if it cant keep trims and railpressure in check. But yeah dont get on it and the car will have best chance dealing with it in higher rpm and low load.
Drive like normal human being for 100 miles. Top off with pump gas. Problem solved.
That should be around E40Yeah, tank is 13 gallons, but I already had e85 in there from previous tank. It was 5gal e85, 7 gal 93 and I previously had about 30% in the tank
https://www.tuneplusinc.com/pages/tuning-tools
DO the italian tuneup and drive at 4k for 30 mins. Get you sucking that tank down REALLLYquick.
Is that on a Mustang dyno? I was posting corrected numbers, no smoothing.581* Quit sellin me short.
