Okay apologize in advance for the noob question. I just discovered that a gas station near my house has e85. I’m about to go is38 on my Alltrack. Can I run the apr is38 93 octane tune and use a blend of 91 and e85 in my tank? If so what should my gallons of each mix be at fill up?
I ran e30 (91 blended with e85) on is38 93 tune for while and ran perfectly fine. It trapped 119mph on the strip. Running e30 I'd consider tops on an ots tune though. If you have obd11 you can monitor it to see how it is running just in case.
I just added the gallons refuel amount on mfd. Then just multiply by 0.23 to take into account the 10% ethanol already in gasoline. That should give about e30. Realize that e85 varies greatly, but on ots tune, won't really matter as this calculation will always give you below e30.
Received a phone call saying they tested the unit and it was defective, new unit is in the mail and they sent me a few bucks via PayPal to cover my shipping expense.
So far their customer service is 10/10. Responded to my initial email on a Sunday (same day it was sent), called to explain what was wrong with my unit, apologize and send a replacement immediately. Good shit.
Hi, want to install the Walbro 450 LPFP F90000267 (Golf 7R with 500 HP).
Can anyone tell what exactly to change in the ECU software.
All say when installing the Walbro 450 kit by Precision Raceworks or by APR it needs modification that the higher elect. power does not burn the stock controller. Can anyone provide information. Up to now it seems too much rumour. Thanks a lot.
I plan on running E85 on my mk7.5 golf R down the line. All I need is upgraded injectors, upgraded fuel pump, and a flex fuel sensor, right? Of course, a tune as well. On my 5th gen camaro ss I could have ran E85 on the stock pump and injectors if I was just going to stay basic bolt ons, but I knew I had more mods planned so I decided to upgrade to zl1 fuel pump and zl1 injectors with a gm flex fuel sensor.
I was looking at “Fuel it” flex fuel Kit, and possibly getting the Precision Raceworks injection kit or the APR fueling system upgrade and that includes injectors, pump, and fueling rail. The precision raceworks doesn’t include the fuel pump. Any thoughts? I haven’t seen anything really online about people running full E85.
I plan on running E85 on my mk7.5 golf R down the line. All I need is upgraded injectors, upgraded fuel pump, and a flex fuel sensor, right? Of course, a tune as well. On my 5th gen camaro ss I could have ran E85 on the stock pump and injectors if I was justgoing to stay basic bolt ons, but I knew I had more mods planned so I decided to upgrade to zl1 fuel pump and zl1 injectors with a gm flex fuel sensor.
