FooDogg
- Right on the Left Coast
- 2017 Alltrack S 6MT
66k; 3/8 inch low, no leak topped off
66k; 3/8 inch low, no leak topped offView attachment 185482
So, how does this overflow canister cap work? Does the radiator get so hot it expands enough to overflow?I see something like dried milk right over the midway point outside of the overflow canister. Probably came out the cap at some point.
Could it have been due to the angle of vehicle on a road, g-forces, loose cap?
Had an experienced shop owner who did oil change specifically check around water pump/thermostat housing and engine compartment from top and bottom, removed the skid plate- confirmed no sign of leaking coolant there...
Hmmm.
Wary as I've had a thermostat housing replaced due leak under warranty-known problem and apparently new oem parts are no different...
