Sorry for the misunderstanding; I was trying to check my mpg, usually that's what it will show up on the screen unless there was a message. Like the one I usually see is the windshield washer liquid running low or tire pressure low.
I also said there was nothing popping on the dashboard screen. maybe it was because the car was running. There is the same message when I turned off the car and the same msg is prompted at engine start too.
Did you solved this problem" ? I have the reminder allways on too , every time I turn on\off the ignition and on the vehicle status too...Already tried a few things with OBDeleven but it didn't work
(I know this was 4 years ago)
This is also what I gathered. Best do as the car commands.I haven't had mine long enough nor have I devoured the manual completely, but that image to me says your oil change is due in 4,700 miles. I could be wrong.
Can't you only reset it after the "change oil due" message pops up? I don't think you can reset the oil change due in x number of miles.
Hmm, good question - honestly not sure
I haven't been able to get rid of the oil change due in x number of miles only when it says oil change due.
It's a PITA to see that message for over 4000 miles. Why VW felt the need to put that message up with so many miles to go I don't understand.
This video seems to indicate that this method actually resets the counters that trigger the reminders (it shows how to reset the inspection counter as well). I would think this means that regardless of when you perform the reset (service in X miles or service now), the counters are actually reset and all reminders are cleared/reset as a result.
The counter is set for one year. During the cars final prep for sale to consumer, it is supposed to be zeroed out. Many dealers jack that up, and you are called to do a change 2mo after purchase.
I've gotten that oil change reminder but this time mine says "inspection due in..." car has about 43k miles
