Suspension modeling
xXDavidCXx
AZ
2017 GTI SE DSG
Right so say you take the 400lb/in spring we were talking about before and you have 2 degrees of roll which might put you through 0.5 inches of travel. Making up reasonable numbers here this would have to be modeled. This gives you 200lb of roll resistance.
Now a 22x2mm roll bar, depending on how its mounted, might provide on the order 100lb of roll resistance per degree of roll.
Its reasonable to say that in this case that half of the roll stiffness might come the bars and half the springs. Now street tires can only take so much wheel rate. In this case we need the roll bars to make up the difference.
I've calculated that the wheel rates for the Hochkis front bar on soft is 367 & stiff is 413.
I don't have any measurements of the OEM front bar, or the 034 rear bar. Let me know if you have those lying around.
Oversteermybagel
Boston
mk7 2017 GTi Sport
I do not. But Hotchkis says their front bar is 95% stiffer than stock in soft and 125% in hard. 367/195=188 413/225=184. I'd guess 185 sounds about right
xXDavidCXx
AZ
2017 GTI SE DSG
Okay, further investigation into my spread sheet found another error. The bar diameter was 1 inch, but should be 1.25 inches bringing the new bar rates to 934/1112.
And it's hollow, need to do more work the get the correct info.
burgerkong
Ontario, Canadeh
Post a review! I'm going to order them but won't get them on for a while.
Only thing I know is that it won't clear some BBK since some change the rotor offset which means the BJ now hit the rotors:
00Zero
Pittsburgh, Pa
I have found the following for the rear bars.
I haven't taken into account changes in the bar arm lengths. I know the diameters and thickness on the vw and eibach are correct (tuv certs and a call into eibach us) the rest are based on MFG quoted increase over GTI or bar dimension calculations.
Rear
SizeODThicknessStiffnessIncrease over GTISolid dimStiffness
[mm][mm][mm^4][%][mm][lb/in]
Golf19.63104581-41%18.0196
GTI PP20--16000020.0333
Clubsport S21.73.617753211%20.5369
22mm solid22--23425646%22.0488
whiteline mid22.5--25628960%22.5533
whiteline stiff23--27984175%23.0582
eibach eu254.7331401107%24.0690
Hotchkis716
eibach us256.4367736130%24.6765
034 soft25.4--153%25.4842
034 mid164%877
034 stiff174%912
HR Race26456976186%26.0951
Neuspeed race26.42487227205%26.41014
00Zero
Pittsburgh, Pa
Similar data on front bars.
Front
Mfg.ODThicknessStiffnessIncrease over GTISolid dimStiffness
23.23.5220828-15%21.7136
22234256-10%144
vw243.82594370%22.6160
e-golf254.030710418%23.5189
2433177628%24.0205
whiteline24.536030039%24.5222
2539062551%25.0241
h&r2645697676%26.0282
eibach EU28445465675%26.0280
50590195%26.7312
557789115%27.3344
eibach US296.35636690145%28.2393
28614656137%28.0379
xXDavidCXx
AZ
2017 GTI SE DSG
Rear
Hotchkis716
034 mid164%877
034 stiff174%912
There are only 2 holes for the 034 rear bar. The mid value does not exist.
