** Support GolfMK7 by making your wheels and tires purchases from Tire Rack **
JJ-R32
Administrator
Staff member
I'm happy to annouce that The Tire Rack is now sponsoring this wheels and tires forum. I'm happy because as many of you might already know its a great company that has, at least for me, always given me top level service. We've added a banner link to tire rack from the forum and I'll drop a link down below.
If you do any shopping from tire rack, please click through from the links on our site before you do the shopping, it helps us keep GolfMK7 alive!
The Tire Rack link: http://www.tirerack.com/a.jsp?a=BJ9&url=index.jsp
The GolfMK7 Tire Rack Upgrade Garage: http://www.tirerack.com/affiliates/live/index.jsp?AFFCODE=AT9
Ricked_Em
STL
I really wish they did some type of financing. All the local shops by me offer 6 months no interest etc. Hard to beat
I had wished that Tirerack offered wheel locks for the OZ's I purchased.
They did provide bolt info and I think I have located some.
Even if Tirerack does not sell, would be nice if they could recommend a source.
Or a contact with OZ who does sell some locks, for my wheels.
In for a discount as requested. Might be late for me. Order placed.
Rod Paine
Yes, I asked Sonny about wheel locks for the 18-inch O.Z. Ultraleggera's last week, but never got a part number so I could order them. Unfortunately the bigger problem is now availability of this wheel, which is now mid May! So I start looking at other options tomorrow. I should have ordered earlier, but with all the snow we've had my priorities were elsewhere.
-Rod
-Rod
Have you looked at the Leggera HLT wheel?
snobrdrdan
former GTI owner
-Rod
I've used Gorilla small diameter ("tuner") lug bolts...that's what Discount/America's tire carries.
They have their own socket for the lug bolts & they do sell the locks for them too, separately. The cool part is that the lock bolt "key" will work with the lock AND will take off the other regular (non lock) bolts....pretty trick. Only one socket needed
(the regular socket won't take off the lock bolt though)
Assuming they take a 14x1.5 & are cone seat....available in 30mm (17019SD) or 32mm (17020SD) lengths:
http://www.gorilla-auto.com/small-diameter-lug-bolts
The wheel locks weren't stocked by Discount tire though & I ordered from Summit Racing, IIRC
NJMK7R
Central NJ
Thats pretty trick. My locks won't fit my VMR so in a similar situation.
Sent from my SM-G920V using Tapatalk
Sonny@TireRack.com
sonny@tirerack.com
PM me your order number and I can double check on wheel locks. Unfortunately there were no alternative locks (sometimes not all lock options appear on the site, so it can be beneficial to call).
Tirerack order!
Got my new Leggera OZ Wheels. (18" X 8"
Covered in Bridgestone RE-11's 235/40R18
Love them.
Balance and Uniformity great.
Just need some wheels locks. Tirerack said back ordered till May.
Tirerack - do you also carry black bolts?
AR11
CA
Hi Sonny,
I'm interested in the new tire TR branded "C4" wheels. These seem ridiculously cheap -- would you still recommend these for track duty? Any word on weight? Are there wider options like an 8.5 or 9 (running more camber than stock)? Construction type?
Thanks!
Sonny@TireRack.com
sonny@tirerack.com
We haven't gotten our first shipment yet to weigh. Most of the TR Motorsport wheels are a pressure cast and reasonably light. Since I don't have any legit experience with it yet, I don't want to put a 100% mark of track approval. That being said, based on past experience, they should be fine to use.
MikeGmk7
PA
I love Tire Rack....the selection, the prices....but I had a very bad experience having tires mounted at a local Goodyear tire place. This was back around 2002, when I purchased tires from Tire Rack and had them installed at this local "participating" tire store. First, they seemed very pissed that I had not purchased tires from them. They treated me indifferently and it took a long time to do the work. But worse, about a month after this I was changing the oil (1998 Passat, V6, 5-speed...great car!) and did some routine checking and saw that not one but BOTH CV boots were spewing grease....and the car only had about 65,000 miles on it!!! Upon further inspection, I noticed that these boots were both slit very cleanly...no jagged break in that rubber, no Sir, the split on each started with a very clean cut, almost like someone (hmmmm, who?) took a razor or a box cutter and helped make it happen.
Now, you might call me a conspiracy theorist here, but I recalled when I left the tire store the guy made a point of telling me they did all kinds of service there, including CV joint replacement. I'd bet my house on the fact that they slit my boots and was hoping they'd have me in there for repairs, or if not then they had the satisfaction of getting revenge on my for not purchasing my tires there.
I did not confront them on this, because I know how that goes. I just made a rule for myself that I would only buy complete tire/wheel packages from Tire Rack, rather than trying to take advantage of their great prices on tires but having to deal with a local shop on the mounting/balancing who might or might not be peeved that they didn't make a tire sale.
Anyone else have a bad experience like this?
