I got the SP LCAs warrantied and noise went away. That was at roughly 15K miles of use.
Two years later it is slowly creeping up again on the new set. Haven't kept track of mileage but I'd guess I am 15K+ and below 25K miles.
If you want it knock free. I'd do the bushings on the OEM arms (they are different) for caster but would likely require CSS knuckles for camber adjustment (which are more expensive).
This all assuming that is your knocking issue.
You guys are reinforcing my decision about these arms, haha. I had a set of the SuperPros ready to install then read about potential noise. I'm a "comfort guy" so noises are a no-go. But dammit they were beautiful!
I ended up going with WhiteLine arms instead. I don't know how they compare from a quality/longevity standpoint, but they have been problem and noise free through 15-20k. Plus I got the ones with more added caster (they have two part numbers) since my car is at stock height so rubbing risk is minimal.
@Mosquito Thanks for chiming in
I bought mine back in Nov '19 but lagged on getting them in until April of last year. 6k miles on them. I'm sure I'm screwed on warranty. Copy on "assuming that it is your knocking issue" but I dont know whats left at this point.
Every bolt has been gone through torqued to spec. PSS10's have come back out, new strut bearings, and strut nut loc-tite to spec. New Whiteline end links. Shop has done the once over 2x now and they are one of the best VAG shops here in Denver. Its frustrating!
I'd do the stock arms but man I'm at -2 degrees camber with the Eurosports and the LCA's dont want to backtrack any more there. The CSS knuckles are out of control $ now.
@Cuzoe I guess thats an option...go with the Whitelines! I'll be super pissed off to go through the work though and not solve the clunk. I guess its do that and hope or just live with the noise for me.
