cb1111
Newbie
- Virginia, USA
Hmmm,
Please explain that. Given the same potential at the amp, cutting the impedance of the load (speaker) will increase the output current. Power equals potential times current. More current equals more power. It's similar to how upgrading to a higher-power light bulb will result in brighter light without changing the supplied voltage.
The specs clearly state that the amp outputs 175W @4-ohms, 300W @2-ohms, and 500W @1-ohm. I had to adjust some settings because (drum-roll) the bass was louder with the new load (more power).
How am I wrong?
Scott
You might be right. It has been 40 years since I did this stuff.
Cheers
